Results 1 to 4 of 4
Thread: I have a code 27 on an 84 SDV
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    I have a code 26 on an 84 SDV
    Code 26
    is a shorted TPS. I checked the TPS itself and all was fine. I back traced the wire harness to it and discovered that a wire behind the idle control motor harness was pinched under the A/C compressor bracket! I pulled the wire out and taped up the bare spot. Now that enabled me to erase the code, but at any RPM above curb idle that code reappears. My manual says if no short I have a damaged ECM. I think the pinched, shorted wire damaged that circuit in the ECM and will require ECM replacement. If I raise the throttle to clear the idle speed motor, the motor shaft retracts until it virtually bottoms out. Allowing the car to run at idle, eventually the shaft on the idle control motor extends out to compensate for the compressor load. I cannt press and retract the shaft to get the gap adjustment. Would you agree, I need an ECM?
    Feb 2003
    california
    69
    6,688
    Re: I have a code 27 on an 84 SDV
    My mistake! Code 26
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Code 26 is a shorted throttle switch, not TPS. Don't confuse it with the TPS - which would throw a code 21 if shorted.
    The throttle switch is located inside the ISC. The switch's job is to tell the computer when you are off the throttle, so that the computer knows its time to idle the engine. The switch closes when the throttle hammer contacts the ISC shaft. That's why you are experiencing odd ISC operation with this code. When you raise the RPM's, the computer still thinks you are off the throttle due to the shorted switch - therefore it continues to try to lower the RPM by retracting the shaft. I would assume the code sets because as it retracts the ISC, it doesn't see the TPS angle or RPM change accordingly.
    Sometimes, you can disassemble the ISC and clean the switch. Else, you'll need to replace it.
  5. #4
    Feb 2003
    california
    69
    6,688
    THANK YOU!!!! Couldn't see the forest for the trees! will be replacing the ISC Monday.
  • You may not post replies
