Results 1 to 2 of 2
Thread: Oil change and now the light wont go out.
    Jun 2005
    1
    Anybody experienced this ?
    I just changed the oil and now the light wont go out !
    I run it and shut it off and try a little more and shut it off and I've cranked it over with the batt feed to the dist pulled and it's not making oil pressure.
    Pulled sender - no oil took filter off and filled it full of oil and put it back on and still no pressure.
    It was fine before I drained it.
    Somehow it's lost prime, and I have to wonder if anybody else has seen this
    93 4.9
    Thanks
    Msilva954's Avatar
    Msilva954 is offline Cadillac Owners Connoisseur
    Automobile(s): 92 Deville
    Aug 2003
    Orlando Florida
    29
    1,725
    Re: Oil change and now the light wont go out.
    Hold Range and Reset
  • You may not post replies
