Removing cat-converter...good idea or no?
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, Removing cat-converter...good idea or no? in Cadillac Engine Discussion; Just wondering what would happen if I remove the cat converter and replace it with a pipe of its length ...
    Msilva954's Avatar
    Msilva954 is offline Cadillac Owners Connoisseur
    Automobile(s): 92 Deville
    Aug 2003
    Orlando Florida
    29
    1,725
    Just wondering what would happen if I remove the cat converter and replace it with a pipe of its length and some clamps?
    Ive got the most horrible rattling noise when the car idles...and I know for sure that its comming from the converter..
    Anyone out there done it already to a 4.9?...will it effect the gasmileage or computer any?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Removing cat-converter...good idea or no?
    Besides any legal troubles with inspections, it will improve the flow of the exhaust. You may get better mileage as well. The universal cats are cheap, why not put one in?
    Msilva954's Avatar
    Aug 2003
    Orlando Florida
    29
    1,725
    dunno...thought about it but free seems better then cheap im just wondering if itll play havoc on the computer sys, im not in the mood ever to see a check engine light etc...
    damn...i really need to scrap to get that dynomax
  5. #4
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    49
    7,531
    Only OBD2 cars will know the difference. Some EGR valves are calibrated with a certain amount of backpressure (aka , the positive and negative backpressure EGR valve types) and will open at the wrong time causing some potential drivability issues.
    Most are positive types. Meaning it takes a certain amount of pressure to even allow the valve to start to open, lose the pressure and EGR doesn't function often at all, so pinging might start to occur. So then you have to run higher octane or reducing timing, often at the expense of what you were trying to gain.
    So, if it works, leave it alone, if not, then take the chance, if it fails to work well, then put one back in....
  6. #5
    Edahall's Avatar
    Edahall is offline Cadillac Owners Enthusiast
    Automobile(s): 93 & 88 Allante, 88 Eldorado
    Jan 2004
    778
    You might try disconnecting and plugging the vacuum hose that goes to the EGR to find out whether or not it pings.
    I've got my EGR disconnected and it doesn't ping even with 3 degrees advance and the cheap 87 octane gas.
    Instead of removing the cat. How about rodding it out. You can lower the cat by unbolting it from the collecters. Take a large hammer/rod and break up the honey comb innerds. Once finished, connect the hollow cat back up. Start the engine up and rev it several times and watch all the junk fly out the end of the exhaust pipe. You might want to disconnect the muffler before doing this since your wouldn't want all the junk to end up in there.
  7. #6
    Msilva954's Avatar
    Aug 2003
    Orlando Florida
    29
    1,725
    hmm that sounds like an idea...im starting to smell a faint gas smell and I know for a fact its comming from the Cat..i may try that suggestion...sounds like my best bet.
  8. Remove Advertisements
