E39 Code
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, E39 Code in Cadillac Engine Discussion; I know this code means VCC engagement problem. It is new on the my diagnostic as of about a week ...
    ja killz's Avatar
    ja killz is offline Cadillac Owners Fanatic
    Jan 2005
    29
    216
    QuestionE39 Code
    I know this code means VCC engagement problem. It is new on the my diagnostic as of about a week ago. What does this stand for or even mean? Is it serious? What should I do about it? Thanks in advance. P.S. This is an edit to the post. I just searched for it and found lots of info on the problem previously posted by bbob, I probably missed it, but what should I do to prevent the code, (not just clear it) and fix the problem?
    adalla is offline Cadillac Owners Fanatic
    May 2003
    PA
    305
    Re: E39 Code
    Quote Originally Posted by ja killz
    Fixing VCC problem maybe costly... You can drive without VCC engagement which may result in 10-15% fuel economy drop.
    ja killz's Avatar
    Jan 2005
    29
    216
    Re: E39 Code
    I dont get how you can drive without it though? It was put there for a reason right? So why just let it go?
    Edahall's Avatar
    Edahall is offline Cadillac Owners Enthusiast
    Automobile(s): 93 & 88 Allante, 88 Eldorado
    Jan 2004
    778
    Re: E39 Code
    First thing to check is the electricals. Do a search "e39" to find information on how to diagnose.
    If this is not the problem most likely, the transmission wil have to be removed from the car to fix it. There's a number of things that could be wrong including the torque converter itself, the valve body or lock up solenoid. If it is any one of these problems, the tranny will have to come out. On the other hand, mine has the same problem and I've driven it 35k miles since and it still works fine other than it burns a little more fuel. When it was working correctly, it would pull 29 mpg on the freeways. Now I'm lucky to get 23 mpg. I can rebuild these transmissions but right now it's not on my high priority list.
  7. Remove Advertisements
