compression test on 1990 4.5L ? constant misfire, idling, under load, coasting...
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, compression test on 1990 4.5L ? constant misfire, idling, under load, coasting... in Cadillac Engine Discussion; Just acquired a 1990 Deville with a 4.5L I have a chilton manual which covers the car, but does not ...
    devillekelly is offline Cadillac Owners Member
    Automobile(s): 1990 deville
    Nov 2013
    55
    1
    Just acquired a 1990 Deville with a 4.5L I have a chilton manual which covers the car, but does not give a number for compression cylinder pressure. Can I run a compression test in the usual manner? And what is a good ballpark number? It has a bad misfire even though the PO said a "tuneup" was just done (to the tune of $500, and the "mechanic" said it was in fine shape now). There is no smoke coming from the car and the oil looks clean and normal. Thought I'd start by checking for a bad plug(s) or wire(s) and then do a compression test... if I don't find the culprit, where shall I look next?
    Thanks in advance for any constructive input!
    Kelly
    onebadsuv's Avatar
    onebadsuv is offline Cadillac Owners Member
    Automobile(s): '91 Allante 135K , '92 Allante 75K , '92 Allante 50K
    Aug 2013
    Sunny South Florida
    24
    Re: compression test on 1990 4.5L ? constant misfire, idling, under load, coasting...
    Greetings - 1990 4.5L Deville engine has the port fuel infection (injection) system . When You pull the plugs , check to see which are black or sooty looking , as they indicate which cylinders misfire ... bad Injectors foul plugs quickly
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Most engines are in the 120-150 compression range. A $500 tune up should include AC Delco spark plug wires or some other high quality name like MSD or Moroso. If they are just cheap wires they will always be suspect. I always run some Techron in any new used car i buy. It is the only snake oil I ever use or recommend. It's always nice to verify plug gaps too because there is a lot of misprints out there. I think these cars are supposed to be .045"
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    I would unplug each injector first to locate the misfiring cylinder. Just like pulling one plug wire at a time to localize the cylinder. Compression tests are done AFTER electrical culprits are ruled out! I'm thinking faulty injector or cracked spark plug.
    ht4100's Avatar
    ht4100 is offline Cadillac Owners Fanatic
    Automobile(s): Triple Yellow 88 Biarritz, 92 Allante, 05 STS
    Nov 2005
    Lincoln, Nebraska
    103
    my 4.9 had 145-150 psi, You could do a compression to rule that out if good. If a tune up has been done, plugs, wires, cap and rotor, fuel filter, etc. I would suspect fuel injectors by your description though, you can ohm test the injectors with a voltmeter and see if they are the specified range.
  8. Remove Advertisements
