P085 ....... Idle Throttle Angle Too High
Results 1 to 9 of 9
Like Tree3Likes
  • 2 Post By BeelzeBob
  • 3 Post By BeelzeBob
HT4100 4.1, 4.5, 4.9 Discussion, P085 ....... Idle Throttle Angle Too High in Cadillac Engine Discussion; 1994 Cadillac DeVille 4.9 The Service Engine Soon light went on while I was driving. When I pulled over and ...
    johnp is offline Cadillac Owners Member
    Jan 2005
    46
    The Service Engine Soon light went on while I was driving. When I pulled over and did a code search I got a P085. Any recommendations for a fix would be appreciated.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,494
    Re: P085 ....... Idle Throttle Angle Too High
    This seems to be a pretty normal problem. Do a search for it there are a lot of posts around here about it.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    It means that the throttle body is dirty and the deposits in the throttle bores are restricting air flow at idle to the point that the idle speed control has no more authority to maintain the correct idle speed.
    Take the air cleaner off, hold the throttle wide open and look down the throttle bores. Spray the throttle bores with carb cleaner and scrub the bores and backside of the throttle blades with an old toothbrush. Cleaning the deposits off the bores and throttle blade backsides it will restore the idle air flow to the correct level. When the throttle body is clean, disconnect the battery negative cable for 60 seconds to reset the idle learn offsets to the "clean throttle body" default values.
    While you are in the throttle body and looking down the bores....see the two tubes sticking up at you from the intake manifold floor just below the throttle blades...??? Those are the EGR tubes and they are NOT supposed to be full of carbon and crud. Rod them out thoroughly with a piece of stiff wire to remove the deposits. Go all the way down thru the tubes to the cast passage below and make sure that they are clean and unrestricted so that the proper amount of EGR can flow.
    Jan 2005
    46
    Thank you Bbobinsky.....Followed your advice and it worked like a charm !
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Occasionally I guess and get one right....LOL.
    ogbuehi is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville, 2011 DTS
    Jul 2004
    washington d.c.
    852
    I know this is an old thread but I used this info when my service engine light. I was able to fix it and it improved my gas mileage big time.
    jlord9485 is offline Cadillac Owners Member
    Automobile(s): 1995 SLS
    Jan 2012
    17
    I couldnt find the two tubes on the intake manifold floor...is there any way you could post pictures or anything?
    philippedussault is offline Cadillac Owners Member
    Automobile(s): fleetwood special sixty 1990
    Jul 2015
    24
    6
    hi guys i know that this is a old thread but i just got the same problems, i already got *all those code E31, E47, E49, E52, F47 and i just got the E85 making my idle to high. Did you think that all my code will disappears if i follow your advice ?
    MSully's Avatar
    MSully is offline Cadillac Owners Member
    Automobile(s): 1991 ElDorado
    Aug 2015
    33
    Have you already addresses those other codes? Do you have a key for what those codes are? Some of those won't be resolved just by cleaning the throttle body and/or the EGR tubes.
  12. Remove Advertisements
