84 cadillac seville chargeing problem
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, 84 cadillac seville chargeing problem in Cadillac Engine Discussion; I have a 84 seville that wont stay running. The problem is it will run for about 15 to 20 ...
    jeff jag is offline Cadillac Owners Member
    May 2005
    3
    I have a 84 seville that wont stay running. The problem is it will run for about 15 to 20 minutes during a drive, and then begin to loose electrical power to the whole car. It acts as if it is the alternator going out but it isnt that or the battery. They both have been changed and tested. I checked the voltage while the car was in park and running. I got 12.04 volts, and the 20 minutes later I got 11.85. It is as if the alternator is not working, and yet it tests good. Is it a relay in the charging system or what?
    SolidGoldsteen's Avatar
    SolidGoldsteen is offline Cadillac Owners Fanatic
    Apr 2005
    132
    Re: 84 cadillac seville chargeing problem
    Yeah it sounds like the alt isn't working, Like you said. Maybe the regulator is bad, or you have a bad connection to the rest of the charging system... I know that's not much help but no one else is saying anything.
    Catillac's Avatar
    Catillac is offline Cadillac Owners Member
    Automobile(s): (2) 1982 Seville Elegantes& (1) 1980 Eldorado Biarritz
    May 2005
    Pemberton, British Columbia
    36
    I don't think your alternator is charging properly...your battery should be reading 14 to 14.5 volts. That's a proper charge to your battery. Maybe it's your voltage regulator?
    With a low charge to your battery, the more power your car uses, the battery can't keep up with the demand on it with such a low charge. :drinker
    May 2005
    3
    Thank you for your help. I'm currently runing a test on the alt. It is stedily droping in voltage output. So I'll try another alternator.
    RickeyGary's Avatar
    RickeyGary is offline Cadillac Owners Member
    Nov 2004
    Chicago
    58
    14
    TalkingRe: 84 cadillac seville chargeing problem
    Your problem is not the alternator or regulator, the air pollution pump has gone bad and is drawing down the alternator. I had this same problem with a 85 Eldorado HT 4100.
  8. Remove Advertisements
