88 eldo 4.5 running temp and code E027 ?'s
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, 88 eldo 4.5 running temp and code E027 ?'s in Cadillac Engine Discussion; I just picked up this 88 eldorado and it seems to be running hot when not moving. Temp. reads about ...
    fullserviceman is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Fleetwood Brougham
    Apr 2005
    Albany, NY
    37
    244
    Question88 eldo 4.5 running temp and code E027 ?'s
    I just picked up this 88 eldorado and it seems to be running hot when not moving. Temp. reads about 212F to 219F is this normal? Seems kinda hot to me. has a 1 fan on inside of radiator and 1 outside seem kinda slow to me. I am haveing A/C troubles saying the refrigerant is low but it isnt, then I play around with the codes and it will work for a while this has got me very confused. Also getting a code E027 which looks like open throttle switch can that be caused by the idle control motor having the end missing off it? Any help here is appreciated on this being this car was a freebie with a perfect body and interior its worth fixing properly.
    Apr 2005
    Albany, NY
    37
    244
    Re: 88 eldo 4.5 running temp and code E027 ?'s
    I meant to say also when the A/C is actually working and im idleing the fans seem to work properly and be on all the time as they should running temp stays at about 213 degrees.. But when the A/C screws up the fans do not run very long at all and my temp goes above 220 at a stop idle.....
