Dangers of flsuhing HT4100 with motor Flush and Supertech oil.
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, Dangers of flsuhing HT4100 with motor Flush and Supertech oil. in Cadillac Engine Discussion; Since it's raining and I can't change the oil for the first time since owning it, I thought I'd let ...
    SolidGoldsteen's Avatar
    SolidGoldsteen is offline Cadillac Owners Fanatic
    Apr 2005
    132
    Since it's raining and I can't change the oil for the first time since owning it, I thought I'd let the question sit up here for a couple while I wait for it to stop raining.
    I was planning on flushing the motor (~40K) with Gunk brand (gray bottle) motor flush and SuperTech oil, with a PurolatorONE oil filter...
    My main concern is knocking loose any particles that could damage the engine while it's flushing. Also, I could add some ATF to the mix if that would help... My frined tops off his eninge (1969 BMW 2002) with ATF.
    FRANKO is offline Cadillac Owners Fanatic
    Automobile(s): 1978 Seville, 1979 Seville, 1979 Seville diesel, 1980 Eldo
    Feb 2005
    Mesa, AZ.
    142
    Re: Dangers of flsuhing HT4100 with motor Flush and Supertech oil.
    Stick with changing the oil every 500 miles for a few sessions. Your detergent oil will do the job. FRAM is the best oil filter, in my opinion.
    FRANKO
    Apr 2005
    132
    Franko, thanks alot for the tips, and for writing, but I don't know if I can take advice seriously from a guy who regards FRAM as the best filter
    Highly-fequent oil changes with some ATF does make sense, though... I wouldn't use SuperTech for driving, I just buy it for flushing because it's $4.88/5 liters.
    leftoverture is offline Cadillac Owners Fanatic
    Apr 2004
    Lester Prairie, MN
    100
    I think you've got to be careful what you put in these engines, maybe Bbob will reply with solid advice. I just change my oil regularly and use the Delo or Rotella 15W/40 like has been recommended here. My 83 has 115,500 miles and still running strong.
    And I use Fram filters, too. . .
    Feb 2005
    Mesa, AZ.
    142
    Seriously or NOT, Consumer Reports did a study on oil filters several years back...FRAM came out #1.
    FRANKO
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Forget flushing or cleaning your engine or putting anyting but high quality oil in it.
    There is simply no reason to flush the thing. Run clean oil in it and let the oil clean it out...if it needs cleaning...which it probably doesn't.
    The best thing to do is to simply change the oil on shedule and leave it alone. ATF was NOT meant for an engine crankcase. There is no reason to put it in the engine. Don't do it.
    Have you taken off the oil fill cap and looked inside the valve cover to see what it looks like inside..?? Chances are it is nice and clean and perfectly fine. I light golden color from the oil over the years is normal and doesn't hurt a thing and should not be cleaned or flushed away. It is harmless to have the light "varnish" on parts as it does not form in moving part interface so it doesn't hurt a thing. Leave it alone.
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    I'd stay away from using a flush. Even if the engine does have a decent amount of sludge inside, it's much safer to slowly remove the deposits rather than risk large amounts restricting the flow of oil by clogging the pick-up.
    Apr 2005
    132
    Wow, OK. I am glad it was raining and I asked...
    That's fine, I'll strip them dry of my favorite High Performance Disel oil and take back the SuperTech and Flush.
    Are there any recommended detergents for removing sludge? I don't know if there is much, but this guy used the oil change places, and so did the guy who I bought my BMW from. They both have the same mioleage roughly, so I'm assuming it has the nasty brown film on the internals, as my Beemer does.
    Thanks guys,
    CT
    Apr 2005
    132
    Returned the SuperTech and Engine Flush!
    Now I need to find out who carries ACDelco filters. I bought Purolator (2 regular and one PureONE) I think I'll go through the 2 cheapies with the 500 mile changes... Shit, I must look like a ****ing moron.
    For my beemer I only ordered OEM!!
    Some pics I took today while I was out. Finally get to enjoy the roads after the cleansing of the rain.
    http://216.93.207.213:8080/incoming/...y1_5-10-05.JPG
  12. Remove Advertisements
