Results 1 to 6 of 6
Thread: Can A 4.1 Trans be Used in a Long?...
    FRANKO is offline Cadillac Owners Fanatic
    Automobile(s): 1978 Seville, 1979 Seville, 1979 Seville diesel, 1980 Eldo
    Feb 2005
    Mesa, AZ.
    142
    My 4.1 (Longitudinal) 1984 Eldo block is shot. Can a 1986, 4.1, DeVille (Transverse) engine be swapped in? If so, how big a conversion would it be?
    Thanks,
    FRANKO
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    Re: Can A 4.1 Trans be Used in a Long?...
    Quote Originally Posted by FRANKO
    Thanks,
    FRANKO
    No. The mounting on the FWD engine block is entirely different from the RWD setup. You're going to have to get a new or running-used 4.1 liter engine for that setup from a RWD car like yours.
    Feb 2005
    Mesa, AZ.
    142
    Thanks for the bad news.
    I wonder how Remanufactured Engines.com does their 4.5 for a 4.1? Would it be a 4.1 block built to 4.5 specs(FWD)? Was the 4.5 Tranbsverse only, FWD?
    FRANKO
  5. #4
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Swap in a 307 Olds, 350 Olds, or any other GM RWD engine with the BOP trans bolt pattern.
    You can swap in a FWD engine with appropriate adapter plates. A 4.9L would be sweet in there....
  6. #5
    Feb 2005
    Mesa, AZ.
    142
    I am the 2'nd Owner of this car(1988)...bought it from Caddy Dealer, took in on trade...22,000 miles, little old lady, etc. I would like to keep it stock...or at least stock-looking.
    Where do I find more info on converting a Transverse engine to longitudinal? I have located a smokin' deal on a 1986 Trans 4.1...58,000 miles on it, supposedly.
    'Preciate the help,
    FRANKO
  7. #6
    fullserviceman is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Fleetwood Brougham
    Apr 2005
    Albany, NY
    37
    244
    I beleive that remanufactured.com uses the standard 4.1 block but runs 4.5 pistons, sleeves, heads. This way it looks and fits like a 4.1 but moves and doesnt fall apart like the better 4.5
  • You may not post replies
