4.9 oil pump in 4.5?
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 oil pump in 4.5? in Cadillac Engine Discussion; Are they the same motors except one is stroked and PFI instead of TBI? Would it work??...
    Formula94lt1 is offline Cadillac Owners Member
    Mar 2005
    35
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 4.9 oil pump in 4.5?
    "Are they the same motors except one is stroked and PFI instead of TBI?" Yes and no. There are differences in the crank, rods and pistons. The heads are also different. The motors are the same family and same construction and such but there are detail differences in the specific parts between the years.
    "Would it work??" Yes, the oil pump, that is.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    49
    7,531
    All years of 4.5? I though the 90 4.5 and the 89 4.5 were significantly different.
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Quote Originally Posted by N0DIH
    You are correct... See corrections in edited post above. The oil pump will interchange which is what the main question was.
    The 89 4.5 was a TBI engine.
    The 90 4.5 was the same bore and stroke but the 90 was PFI and had a light weight piston/rod assembly and as a result the crank was balanced differently. The 90 cylinder heads had very different intake ports compared to the ports on the 89. With the PFI, the intake manifold was quite different. The oil pump will interchange , though.
    From the posters question he mentioned the 4.5 and 4.9 and PFI so I was answering in respect to comparing a 90 4.5 to a 91-95 4.9 only. Should have been more specific.
    Mar 2005
    35
    Thanks, just one more question after reading the replies... Can you swap the 90 4.5 pfI or any 4.9 top end, intake heads and throttle body onto an 89 and older 4.5 block?
    Also say you did put the 4.9 top end on an older TBI 4.5... could you still mount the TBI setup back onto the PFI intake?
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    I found a pretty indepth article going over the differences in all the HT series engines. I wish I knew where it was. Can someone post it if they find it?
    I am confident I found it on CadillacForums.com, somewhere....
    Mar 2005
    35
    That would help a lot, thanks if anyone can find it...
  10. Remove Advertisements
