does ECU prevent engine braking - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
HT4100 4.1, 4.5, 4.9 Discussion, does ECU prevent engine braking in Cadillac Engine Discussion; bbob I was refuring to E55. With bad eye sight and a poor memory its a wonder I get anything ...
  1. #31
    CAPTJACK is offline Cadillac Owners Member
    May 2005
    12
    Re: does ECU prevent engine braking
    bbob I was refuring to E55. With bad eye sight and a poor memory its a wonder I get anything right. All is working good now but now I have stalling problems at startup I have to hold the throtle open a little untill warm up. Is this because of the Idle stop screw beeing backed out too far.
  2. #32
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by CAPTJACK
    At your last post the TPS was not set correctly and the closed throttle switch was not making the indicator light come on unless you tapped the throttle......
    Have you set the TPS to .5 volts when the throttle body is in the closed bore position and is the closed throttle switch working each and every time you take your foot off the throttle..?? If not, then all is not right..... With an improperly adjusted TPS and/or the closed throttle switch not working correctly the system is lost and will have cold start up problems among other things...
  3. #33
    May 2005
    12
    bbob I want to thank you very much I dont know who you are but you sure know cadillac's this thing za purin like a singer soen machine. My first cadillac 110000 mi and tight as a drum I dont know what all this talk about the 4.5L too small for all that iron but this 89 Fleetwood is definatly Fleet a Foot. The owner was worried about the price of gas But im getin 18 in town and 24 on the road For $2500 I dont know what he's thinken but he will spend $20000 to get 35MPG Ill sell my honda for $8000 and buy a lot of gas and a trip to Jamaca. And if I ever run into the previous owner I hope for his sake its not with this "1989 FWD Cadillac Fleetwood" I love this car.
