Oil leak
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, Oil leak in Cadillac Engine Discussion; Have a 92 deville, oil leaking from like four different areas. Is it worth getting fixed?...
    eggieson is offline Cadillac Owners Member
    Apr 2005
    1
    Oil leak
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    Re: Oil leak
    well it depends , got any ideas on eaxctly where its leaking ?
    how much oil are you looseing ?
    do you like a clean driveway ?
    ELDORADO2K is offline Cadillac Owners Member
    Feb 2005
    Los Angeles,CA
    27
    Re: Oil leak
    I have the same problem on my 92 4.9 liter Eldo. I've been giving it more and more thought lately as it seems to leak alot on the drivway. It drinks"spills" about a quart every 1000 miles or less now, more than ever and its startin to bother me because I plan on keeping my car around. Does anyone know how much the dealer for example charges to replace the oil pan gasket? Cuz I looked under the other day and it wasn't a pretty site. Autozone sells it for $22 but the labor on having it installed might be large dent in the wallet. What do you guys think?
    BodybyFisher Guest
    Re: Oil leak
    As with any engine things need to be replaced over time. The 4.9 has a number of items that can cause oil leaks. The easiest to fix are the cooling line o-rings that attach to the oil filter adapter and the radiator, the square cut seals behind the oil filter adapter and the valve cover gaskets. The oil pressure switch/sender on the oil filter adaptor can also leak. You need to look it over closely to see where its leaking from..
    In terms of replacing the oil pan gasket, it can be done and the pan will come down on the 4.9 to replace the gasket.. Mike (Scotty from Caddyinfo)
    Phil_H is offline Cadillac Owners Member
    Automobile(s): 1992 Sedan deVille
    Feb 2005
    United Kingdom
    Re: Oil leak
    I changed one on my 92' SDV. It was simple enough, though you will probably have to saw / file one of the corners off to get it back on. If it's the original gasket, it's probablt got spacers "in built" so you can't tighten it down ant further. Since I did mine, I've had no probles and the drive is clean.
    Phil
  8. Remove Advertisements
