Service Soon digital dash Out
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Crackillac
  • 1 Post By carnut
HT4100 4.1, 4.5, 4.9 Discussion, Service Soon digital dash Out in Cadillac Engine Discussion; I have an 86 coupe deville which i accidentally Jumpstarted with the terminals reversed. It blew fuses in both fuse ...
    Crackillac's Avatar
    Crackillac is offline Cadillac Owners Member
    Automobile(s): 86 Coupe DeVille
    Mar 2009
    Shreveport, LA
    30
    85
    Jumpstarted with the terminals reversed. It blew fuses in both fuse blocks which i replaced. The car runs fine but none of the digital
    Dash lights will come on. The radio plays but no time or station display. No speedo or mpg display. The Service Soon light is on. Is this something they can check at autozone with a computer device or have i blown up or melted down some computer board?
    Feb 2003
    california
    69
    6,611
    Re: Service Soon digital dash Out
    I think you shorted the BCM (Body control module) You have a code reader in your car already. AutoZone wont be able to help.
    Crackillac's Avatar
    Mar 2009
    Shreveport, LA
    30
    85
    Took me a while to get around to this project but i pulled the bcm today and im no expert with circuitry but i don't think these little things are supposed to be melted together like they are.. Or maybe im wrong, i really don't know what I'm looking at lol
  5. #4
    Feb 2003
    california
    69
    6,611
    I would think any computer repair shop should be able to tell you by looking. There is also a "constant power supply module" located just above the gas pedal that can be shorted out. About the size of a pack of cigarettes, silver. Its held vertical with 2 8 MM ? nuts on a bracket. You can remove the nuts and it will drop down and dangle by the harness plugged into it. It will say CONSTANT POWER SUPPLY on its white label. I damaged one of those by hooking up an aftermarket stereo once and digital dash display went blank. You'll find them on 86 thru 89's I believe.
  6. #5
    Feb 2003
    california
    69
    6,611
    Disregard the mention of the constant power supply! Got my models mixed up. Eldos and Sevilles had them, not coupes and Sedan DeVilles. .
  7. #6
    Crackillac's Avatar
    Mar 2009
    Shreveport, LA
    30
    85
    In ended up getting a BCM out of a 86 blue sedan at the junkyard for $35. Plugged it in and tahdaaahh Brain transplant complete and everythings working again
    carnut likes this.
  8. #7
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Yeah I blew the ECM on mine jumping it backwards, ended up replacing it and the BCM both
  9. #8
    Feb 2003
    california
    69
    6,611
    You are welcome.
    Crackillac likes this.
  10. Remove Advertisements
