E046
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, E046 in Cadillac Engine Discussion; E046 Right to Left Bank Fueling Difference. Anyone have this problem? Know the fix? The car is a 90 Seville ...
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    QuestionE046
    The car is a 90 Seville 4.5L
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: E046
    Sounds like it might be a clogged/failing injector, or bad plugs.
    A test of all the usual suspects is in order.
    For testing the fuel side, I would check (in order), spark plugs (including wires and cap), and then the injectors.
    I would also look for intake/exhaust leaks at the manifolds (intake and exhaust).
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: E046
    On a '90, the AIR system is often the culprit for this code. The diverter valve tends to fail and is stuck routing fresh air to the exhaust manifold, which is detected by the O2 sensor, creating a fuel trim difference between banks. Check the operation of the system.
  5. #4
    Feb 2009
    Jacksonville, FL
    1,023
    Re: E046
    I keep forgetting about the AIR system....good call...
  6. #5
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Re: E046
    Quote Originally Posted by drewsdeville View Post
    I kinda figured the place to start was the O2's, but now I'll look at the diverter valve first. Thanks!
    Where is that located by the way?
  7. #6
    Oct 2004
    Oak Creek, WI
    5,609
    Re: E046
    behind the cruise control servo. Plastic assembly with a bunch of hoses coming off of it. If you are confused, follow the hose coming from the front exhaust manifold. It hooks to the diverter valve.
  8. #7
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Re: E046
    Cool! Thanks. I'm heading to the salvage yard today, I scouted it yesterday and spotted a low mi, very clean, well maintained, 90 Seville with a lot of new stuff and the front end smashed so hard the engine and trans cases broke. I plan on stripping the diverter valve, Egr valve dist, fuel rail w/injectors, everything I can, including the interior which is the same color as mine but mint. SCORE!
  9. #8
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Re: E046
    Update;
    I changed out just the diverter valve with one I obtained from the salvage yard and so far the DTC E046 hasn't returned, but performance and fuel economy has!
    A big THANKS! go out to drewsdeville.
  10. #9
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Re: E046
    Its back!!! AND IT IS WORSE! I did a fuel pressure test and got nothing! But the thing starts and runs very crappy for a couple of min. Then the pressure kicks up to 30+ psi. When I shut it off and then turn the key to on with out starting, fuel pressure goes to zip. I replaced the fuel filter and got no results. And yes there is gas in the tank. As a mater of fact there is gas to the fuel rail, just no real consistent pressure.
    BTW, OBD trouble code E046 Right to Left bank fueling difference has returned.
    I listened to all the injectors with a mech’s stethoscope, they all sounded like they were functioning.
    I’m hoping someone has a tip or idea of which maybe it could be.
    Thanks in advance.
  11. Remove Advertisements
