OBD confusion
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, OBD confusion in Cadillac Engine Discussion; ...
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    QuestionOBD confusion
    My 90 Seville 4.5 with 340k mi has been running poorly, low mpg.
    The OBD kicked up code “E053” I looked up the code and found “Distributor Signal Interrupt”.
    Question:
    What does that mean? Other than the obvious (signal interruption in the distributor)
    What is the most likely part to fail?
    Where and how to perform repair / replacement?
    Any advice on what to do?
    Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Check the wiring going to the distributor, but a fairly common problem is the connectors to the ICM inside the distributor. They crack and come loose. I know there're a few threads with pictures floating around. Search for 4.5, 4.9 or Deville ICM replacement. Or just google "cadillacforums E053".
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Re: OBD confussion
    Alright! A place to start. Thanks MC.
    HUF's Avatar
    HUF
    HUF is online now Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    Re: OBD confusion
    +1. It was impossible not to break that connector when I was replacing ICM. One can still use the connector, but has to carefully clean the distributor off the broken off plastic pieces.
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Re: OBD confusion
    Thanks again Guys for the information. Good news! I installed a new ICM and the DTC “E053” hasn’t returned.
    BUT! A new code took its place, “E046”; Right to Left Bank Fueling Difference. ?????
    Again I ask;
    Thanks
  8. Remove Advertisements
