strong gas smell after motor turned off and exiting the vehical...no codes...95 devil
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, strong gas smell after motor turned off and exiting the vehical...no codes...95 devil in Cadillac Engine Discussion; there is a strong gas smell while ideling and after the car is shut off ...don't see any leaks just ...
    eddielnordman's Avatar
    eddielnordman is offline Cadillac Owners Member
    Automobile(s): 1995 DeVille 4.9L (with skirts)
    May 2013
    phx az its hot over here
    42
    63
    there is a strong gas smell while ideling and after the car is shut off ...don't see any leaks just replaced fule pump and went threw emissions and passed easily any ideas....other than that car runs fine 17.6 mpg....????
    68
    81,916
    Re: strong gas smell after motor turned off and exiting the vehical...no codes...95 d
    Sounds like a fuel leak to me. Maybe a leaky FPR, but that should be leaking internally and thus running very rich (still worth checking).
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Just replaced fuel pump and now you smell fuel? I'd assume it's a problem with the install. Could be a number of things - cracked plastic fuel line, torn seal at the top of the tank, rusted filler or vent pipe that was disturbed when the tank was removed, etc... Poke around with your nose in the area of the tank and fuel lines, and you may find your problem
    68
    81,916
    I missed that "just replaced fuel pump" part. Yeah, go back and check your work.
    May 2013
    42
    63
    Ok will check that but the smell was there before just stronger now ....but good point thanks for the help people .....love ths site.
  8. Remove Advertisements
