Why and what is it making that noise? (Video included)
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
HT4100 4.1, 4.5, 4.9 Discussion, Why and what is it making that noise? (Video included) in Cadillac Engine Discussion; Hey Guys, while detailing the car and having the doors open i've noticed odd sounds in a non pattern kinda ...
    DReffects's Avatar
    DReffects is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
    May 2013
    Germany
    338
    Hey Guys,
    while detailing the car and having the doors open i've noticed odd sounds in a non pattern kinda way coming from the engine compartment. I've took my camera and found it to be this part:
    Unfortunatley i do not know what this part actually does/is nor why it keeps making this sound while the car isn't even running.
    thanks!
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Why and what is it making that noise? (Video included)
    That is the air compressor for your rear struts. You must have a leak, usually the struts when they get 20 years old.
    DReffects's Avatar
    May 2013
    Germany
    338
    Quote Originally Posted by cadillac_al View Post
    So that's why the "Service SSS" lamp is on?
    Could you please help me pick the correct struts at http://www.rockauto.com/ ?
    I don't want to loose that auto leveling thingy and electronic ride control, thanks
    Feb 2007
    Maine
    55
    3,310
    Oh yeah, 93 has the SSS struts and it appears that Rockauto doesn't stock them. Probably nobody has them. You could get regular struts and deal with the SSS message. Somebody will come along and clear this up.
    I ran my Deville the last couple years with no air in the struts. It sat level when it was empty but I couldn't put much in the trunk and 2 guys in the back seat made it sag pretty bad. 95% of my driving was solo so it wasn't a high priority for me. You may want to unplug that compressor if it runs too much, to save it for when you do replace the struts.
    DReffects's Avatar
    May 2013
    Germany
    338
    Damn is there an official description/name or a part number for these?
    I found a way to disable the "Service SSS" lamp, but I'd rellay like to have the car in original condition. Is there a downside to pulling the plug on the compressor?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    The tail end will droop.
    Look through your car, model, system in www.gmpartsgiant.com. The level control compressor is trying to keep the rear of the car level. It does not sound healthy. Given the age of the system, the air lines and rear shock boots are probably toast, too.
    Talk to Chris in parts at Rippy Cadillac, over there >>>>>>>>
    DReffects's Avatar
    May 2013
    Germany
    338
    They don't seem to have parts for the rear suspension
    In your opinion - do i loose a lot of ride quality if I replace the struts completely with fixed ones? I am unsure what the 'electronic ride control' actually does. Does it simply level the car when i put stuff in my trunk or is it an active suspesion that adjusts on the fly while driving over bumps like the newer cars have?
    Feb 2007
    Maine
    55
    3,310
    Yes it is active suspension and it is supposedly expensive. I doubt the ride difference would be too drastic. The standard struts just level the car and have normal shock damping. Your best bet is to contact Chris at Rippy to get a definite answer on availability.
    DReffects's Avatar
    May 2013
    Germany
    338
    I've emailed Rippy Cadillac but have not gotten any response yet, I've pulled the plug on the compressor for the time being.
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Montreal, Canada
    445
    You will find what you need here:
    http://www.monroe.com/en-US/catalog/e-Catalog
    If you need a new compressor this one will meet your needs:
    http://www.ebay.com/itm/88-DEVILLE-A...#ht_2816wt_721
    If you want to go the "passive suspension conversion" route, try these guys:
    http://www.strutmasters.com/SearchRe...llac+Fleetwood
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Right now you can buy Monroe SensaTrac rear struts for $35.79 from Rockauto.com You will not be able to find original SSS struts unless some pop up on ebay. They were discontinued in 2000. Get the sensatrac's with the bladder and tie back the harness that goes to the original strut.
    DReffects's Avatar
    May 2013
    Germany
    338
    Thanks for the tip
    RockAuto Customer Service actually recommended
    . ACDELCO Teil # 903002RS {#19294055} ReadyStrut
    and
    . ACDELCO Teil # 903008RS {#19294057} ReadyStrut
    300? 300: true ); height:expression(this.height > 400? 400: true );">
    Aren't those the original replacement parts? Or just Acdelco 'aftermarket' parts without the air thingy?
    Feb 2010
    Orange County, CA
    62
    2,479
    You only have air in the rears. Just looking at the picture, those appear to be correct for the rear. The fronts look correct also and will save you the hassle of changing the spring and upper bearing assembly.
  16. #14
    69
    82,287
    Don't automatically assume it is the shocks. While they ARE in fact 20 years old, so are the air lines. Spray down the lines and fittings with soapy water. Let the compressor run and look for foam. That'll be your leak.
  17. #15
    DReffects's Avatar
    May 2013
    Germany
    338
    Nice trick! Gonna try that before ordering. I've looked closely at the rear shocks and found the plastic 'airbag' to be veeeerrry worn down. lots of ripples etc. Is there a way to test if the front struts are ok or not?
  18. Remove Advertisements
