92 Eldo Problems - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
HT4100 4.1, 4.5, 4.9 Discussion, 92 Eldo Problems in Cadillac Engine Discussion; got some codes that just popped up the first one that says current is A011- I looked it up and ...
  1. #16
    JJhomer83's Avatar
    JJhomer83 is offline Cadillac Owners Connoisseur
    Sep 2003
    Bucks County, Pa
    34
    1,805
    Re: 92 Eldo Problems
    the first one that says current is A011- I looked it up and it said high side temp circuit any clue what that means????
    the others are in history
    e091
    e098
    a040
    if anyone can help me that would be great i am at a loss here
    thanks
  2. #17
    bob2231's Avatar
    bob2231 is offline Cadillac Owners Enthusiast
    Sep 2003
    Tampa, Fl
    55
    520
    Quote Originally Posted by JJhomer83
    e091
    e098
    a040
    thanks
    My book doesn't list any codes starting with A. Sorry. But the high side circuit may be in the A\C system.
    The 091 says PRNDL switch problem.
    098 says High RPM P/N to D/R shift under ISC.
  3. #18
    JJhomer83's Avatar
    Sep 2003
    Bucks County, Pa
    34
    1,805
    Quote Originally Posted by bob2231
    can anyone help me out and let me know how to fix these codes??
    Im getting desperate, can't afford garage labor
  4. #19
    cadfan is offline Cadillac Owners Member
    Sep 2003
    47
    Going off what is being said-091 code PRNDL- the computer is not seeing the correct gear selection coming out of the PRNDL switch. It could be out of adjustment, this isnt that bad. The 098- high rpm is the computer seeing a high rpm reading when you select a gear from park. This is usually caused by the ISC motor being bad. If you said you noticed it running at high rpms, this could very well be your problem. Get yourself a factory shop manual. Hynes/chiltons are no damn good. There are steps for replacing the ISC motor- more than just replacing it- You need to let the computer relearn the settings.
  5. #20
    JJhomer83's Avatar
    Sep 2003
    Bucks County, Pa
    34
    1,805
    FYI to all of you.
    The E091 - PRNDL switch problem
    it has effected my e-brake. to disengage the ebrake your supposed to put the car in gear. I did that and it doesn't come off i have to manually do it.
    The E098 - High RPM P/N to D/R shift under ISC
    It has effected my idle. My car stays at a constant Idle for a lot longer than it should
    The A011 - high side temp circuit
    This could also be effecting my idle
    Anyone know how to correct these problems that would be much appricated. I am soo lost on these problems and i can't afford to pay a garage.
  6. #21
    therock0051 is offline Cadillac Owners Member
    Oct 2003
    Norman Oklahoma
    33
    1
    My 91 Deville had the same problem, turned out to be the idle speed control, the thing would get hung out, and keep the idle high? Maybe this will be some help, don't know if they are the same motor or not.
  7. Remove Advertisements
