4.9 Cable Wrapping Questions
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By EldoRedo
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 Cable Wrapping Questions in Cadillac Engine Discussion; Folks, I am redoing all of my split-loom cable/wire bundle wrappings, and as this is a second engine, most traces ...
    EldoRedo's Avatar
    EldoRedo is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ETC (Crimson)
    Jul 2006
    Bethesda, Md.
    232
    Folks,
    I am redoing all of my split-loom cable/wire bundle wrappings, and as this is a second engine, most traces of "factory" installation are gone. Tonight I redid the main wire bundle from behind the I/P on the r/h side, across the rear valve cover, then down under where the air box would go. This run has several branch points -- am I correct that such junctions are nothing more than the feeders emerging from the split, with the feeder wraps just butting up against the main run? Or, as the drawings in the Service Manual suggest, should these junctions be wrapped with electrical tape?
    In the photo you can see the run I did tonight emerge after it comes off of the valve cover, then it has a major branch near the metal cable clip, and a second branch area a few inches later. I went ahead and ran the new wrap as far along as I could, knowing I can always cut it back.
    And that raises my other question -- the new wrap is a little too big for the metal clip -- suggesting that, at least for thus run, I should be switching to a smaller diameter wrap and not trying to extend the "main" wrap as far as I can?? And THEN the question is -- is it more common practice to always use a new piece (even of the same diameter) when "leaving" a branch/junction?
    Thanks for any help!
    Cadillac_Fan likes this.
    EldoRedo's Avatar
    Jul 2006
    Bethesda, Md.
    232
    Re: 4.9 Cable Wrapping Questions
    Well -- for those interested:
    I have wrapped the junctions with black silicone self-fusing tape. I would highly recommend it. Looks just like electrical tape but none of the eventual melti-ness and loose ends. I also did switch to a smaller diameter after the lower branch above, which worked out fine because I wrapped that area anyway as a junction.
    Only thing I can tell you is that the original factory ends I found (against connectors) were wrapped with maybe half-inch shiny black cloth tape.
    I made the metal clip fit by scrunching the loom a bit inside itself and used a pair of pliers!
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    Looks good!
    EldoRedo's Avatar
    Jul 2006
    Bethesda, Md.
    232
    Well thanks -- here's the final result:
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,109
    Nice. You seem to be a perfectionist!
    EldoRedo's Avatar
    Jul 2006
    Bethesda, Md.
    232
    Yeah I plead almost guilty! I accept that I am not aiming for concours-quality, just spiffing up my almost 24 model-year-old car for my own enjoyment. In this case, I just got tired of putting the hood up and seeing an engine bay that I had let go a little bit. So it's not perfection but a lot better usually when I'm done and that's my goal...
  9. Remove Advertisements
