Waterpmp AGAIN! - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 37
HT4100 4.1, 4.5, 4.9 Discussion, Waterpmp AGAIN! in Cadillac Engine Discussion; Air for about a week? It should all burp out after the car has been driven and warmed up a ...
  1. #16
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,477
    Re: Waterpmp AGAIN!
    Air for about a week? It should all burp out after the car has been driven and warmed up a couple times.
  2. #17
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,128
    Re: Waterpmp AGAIN!
    Quote Originally Posted by Ralph View Post
    guess what. Today I lifted up the reservoir and the hose was twisted! As soon as it untwisted the level increased and I heard another whoosh of air! I hope this takes care of the air in the system but I called yesterday and they said I can expect air for about a week or so. It's a new rad cap. Also they supposedly changed to all new exhaust bolts as they were part of the kit I had to buy
    ^+1
    How the hell did it get twisted? As for a week long waiting for air getting out of the system, it is a total BS. That's why I like 4.9 cooling system - it will clear itself off all air pockets in one-wto heating-cooling cycles. Just watch the reservoir and add some coolant as needed. By the way, Bar's Leaks Golden seal (brown) powder is a must for 4.9 engine. You can get a tube of it from Wal-Mart and pour it right into radiator neck when the system is cold. Do not put it into the reservoir.
  3. #18
    Ralph's Avatar
    Ralph is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac
    Mar 2003
    Saskatchewan, Canada
    16,105
    Quote Originally Posted by HUF
    ^+1
    When the mechanic put the reservoir tank back he was careless, so I took the reservoir off again and untwisted it myself. Problem solved.
  5. #19
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,128
    Re: Waterpmp AGAIN!
    Ah, I see, That was the hose I suggested to check out. I thought you were talking about lower radiator hose.
    Okay, you should be fine now. I would not give that mechanic business. God knows what else he screwed up you cannot see.
  6. #20
    Ralph's Avatar
    Mar 2003
    16,105
    ok went back to the Caddy dealership and they installed the hose they had to orer, it was just part of the pcv elbow or something BUT I drove in with the engine smoking again! (it has been for over a week and I thought it was just spilled oil on the engine burning off) and it turns out it could be the valve cover now, after they just did it! Apparently " the gasket shifted" upon installation and the mechanic said "it is a bad design ." Man I've just about had it
  7. #21
    Jun 2003
    Canada
    6,477
    Re: Waterpmp AGAIN!
    Sounds like they're doing sloppy work. I'd tell them you want a loaner and leave the car with them until they get it all sorted out. Sometimes you need to go back for something very small after a repair like that, but really they problems you are having they shouldn't have told you the car was done until they knew it was.
    We just had the transmission in my 94 Deville rebuilt last year. It was less then your repair cost and haven't had to go back since we picked it up.
  8. #22
    Ralph's Avatar
    Mar 2003
    16,105
    Quote Originally Posted by brougham
    believe me I'm more than a little upset! They have to fix it and it will be covered. I'm just sick of the little ****ups, or so it seems. Also they asked if I was going on the highway and I said not yet, and advised I shouldn't because it could light up. And I am really sick of going back and forth. I expect more from Cadillac service. They can give me the new beigh ATS in the showroom and I might even forgive them
  9. #23
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Waterpmp AGAIN!
    Too bad they didn't have some older guys there that have worked on these cars before. It sounds like this mechanic is working on a 4.9 for the first time. Practice makes perfect; he will probably get the hang of these vc gaskets after he does it again.
  10. #24
    Ralph's Avatar
    Mar 2003
    16,105
    Quote Originally Posted by cadillac_al
    yeah exactly! They are working on it right now and indeed it was the firewall side valve cover and it was smoking and stunk pretty good as I drove it to the dealership this morning. Should be done in a few hours. Hopefully NO LEAKS
  11. #25
    Ralph's Avatar
    Mar 2003
    16,105
    Engine Fire!! Lol when the mechanic was removing the fuel rail to change the valve cover gasket he spilled some fuel on the exhaust manifold and singed his eyebrows and burnt his nose!! Anyway car seems aces now, no leaks, no smoke but I had a lot of white cruddy fire retardant to clean off my engine and windshield.
  12. #26
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Re: Waterpmp AGAIN!
    Tell him to go back to farming wheat.
  13. #27
    Ralph's Avatar
    Mar 2003
    16,105
    haha ya
  14. #28
    Jun 2003
    Canada
    6,477
    Re: Waterpmp AGAIN!
    Make sure you get all that stuff off well, it can be corrosive on some of that stuff and the engine. Go back and complain if it makes more of a mess. I would have expected to them to clean that shit off for you and for after all they've put you thru I would have actually demanded that they detail everything to make up for it.
  15. #29
    Ralph's Avatar
    Mar 2003
    16,105
    oh great, MORE good news. You know I'm just so sick of going there and having to check under the hood twice a day it's insane. I heard so many things about Dealerships the last week. Forexample that they don't care about older cars because they make more $ on newer car repairs under warrenty, so they get the "lesser" mechanics to work on the vintage stuff like mine.
  16. #30
    Ralph's Avatar
    Mar 2003
    16,105
    took your advice today and called the dealership. They let me have one of their carwash bays and I flushed the engine and underneath also. Going to TRY to use photobucket and post some pics of the fire damage, if I can.
    [IMG]<a href="http://s890.photobucket.com/albums/ac101/ralph1239/?action=view&current=4DAA079F-F8B2-4DF3-9C4E-E16AA08C8C7B-665-000001186CA5AE92.jpg" target="_blank"><img src="http://i890.photobucket.com/albums/ac101/ralph1239/4DAA079F-F8B2-4DF3-9C4E-E16AA08C8C7B-665-000001186CA5AE92.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>[/IMG]
    [IMG][/IMG]
    http://i890.photobucket.com/albums/a...186CA5AE92.jpg
    [/IMG]
    http://s890.photobucket.com/albums/a...7CA09D0622.jpg
  17. Remove Advertisements
