88 deville bubbling
Results 1 to 13 of 13
HT4100 4.1, 4.5, 4.9 Discussion, 88 deville bubbling in Cadillac Engine Discussion; I have an 88 Seville and it is gently "bubbling" (more of a water flow than air) in the overflow ...
    VIIISecondRide is offline Cadillac Owners Member
    Automobile(s): 97 Eldo,98 STS,88 Deville, 94 Mark VIII :0
    Dec 2012
    Eastern Colorado
    49
    19
    88 deville bubbling
    I have an 88 Seville and it is gently "bubbling" (more of a water flow than air) in the overflow while idling. When you increase the rpm, it seems to stop. It pushes water into the overflow but won't suck it out. Does that seem to be a hg? It does have some water in the oil. Thanks
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: 88 deville bubbling
    Yes, most likely a head gasket.
    It's repairable, but due to the aluminum block, the head bolt threads will need to be repaired after head bolt removal. Unfortunately, the job is not as simple as R&R'ing the gasket.
    Dec 2012
    Eastern Colorado
    49
    19
    I'm sorry I meant to type deville but spell check changed it :/ . Does the 4.5 have an aluminum block?
    Feb 2003
    california
    69
    6,680
    Yes, its aluminum. You might try a new radiator cap. A weak cap will allow it to boil prematurely and will not allow fluid to be sucked back into the radiator. You say you have water in the oil? is that on the dipstick or oil fill cap?
    Dec 2012
    Eastern Colorado
    49
    19
    The water is in the pan, made it thick and sludgey on the dipstick. It's not gray or milky though. Just about a quart over full.
    Feb 2003
    california
    69
    6,680
    This engine was famous for intake gaskets failing much more so than head gaskets. An intake gasket failure will dump coolant directly into the oil pan. Left unrepaired, it will wipe out the cam, lifters and main bearings! Drain the oil and verify its coolant/ water. report back.
    Dec 2012
    Eastern Colorado
    49
    19
    OK I will. We're having a bit of a blizzard here today
    Feb 2003
    california
    69
    6,680
    Its 40 degrees and bright sun here! no wind. Good convertable weather!
    Oct 2004
    Oak Creek, WI
    5,609
    Or, for a no-nonsense confirmation, test the coolant for exhaust gases. Many cheap kits available at the local auto parts store.
    Given the symptoms, this would be a strange coincidence of multiple problems occuring at the same time for it not to be a head gasket - but anything's possible.
    Feb 2003
    california
    69
    6,680
    I agree!
    Dec 2012
    Eastern Colorado
    49
    19
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I wouldn't run it at all with a quart of coolant in the pan. It doesn't take much to screw up your bearings. I guess I would test the coolant first to determine how the coolant is getting in the oil. If it is the head gasket I wouldn't fix it, I would look for another engine.
    Dec 2012
    Eastern Colorado
    49
    19
  16. Remove Advertisements
