1984 eldorado biarritz
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, 1984 eldorado biarritz in Cadillac Engine Discussion; I have a 1984 eldorado biarritz that has the "stop enine oil pressure" light blinking and "service soon" then "service ...
    joseph29 is offline Cadillac Owners Member
    Dec 2012
    5
    I have a 1984 eldorado biarritz that has the "stop enine oil pressure" light blinking and "service soon" then "service now" light on it idles high sometimes then will die I drove it to my after I bought it and it'll shut off when I slow down or stop. It also reads codes 19 20 24 26 27 52 53 what do these codes meann and how do I fix the problem with it shutting off and idling the way it is
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: 1984 eldorado biarritz
    Try posting in the Eldorado/Seville forum.
    You may get more of a response.
    Duane Hayes is offline Cadillac Owners Member
    Automobile(s): 1985 Seville
    Jan 2013
    63
    6
    There's information on the codes in other threads posted. Sometimes the oil light blinking can be a faulty oil pressure sending unit, (located at the oil filter adapter), the first easy check to do, or thinned out engine oil, or worn out engine bearings.
    Dec 2012
    5
    I fond out that it was a wrong sensor that was rigged up so I replaced the sensor and hooked it up right now car runs awesome but codes are still coming up and the blinking lights (oil pressure ,service now) just stay on I tried resetting but they are still on
  7. Remove Advertisements
