Super high idle - 1992 Fleetwood
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, Super high idle - 1992 Fleetwood in Cadillac Engine Discussion; I have a 92 Fleetwood 60 Special. It idols way too high and I can't for the life of me ...
    bobdt is offline Cadillac Owners Member
    Dec 2012
    16
    I have a 92 Fleetwood 60 Special. It idols way too high and I can't for the life of me figure it out. Does anybody have any idea on what the problem could be?
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: Super high idol:
    Vacuum leak, maybe?
    Dec 2012
    16
    Quote Originally Posted by the recluse
    Vacuum leak, maybe?
    I'm checking into all that in the morning. Intake, injector ports, all lines and EGR. Any other possibilities would be appreciated. Thanks
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    Idle Control Motor or Idle Speed Controller.
    I don't recall exactly what it's called. It mounts to the front of the throttle body and has a plunger that pushes against the throttle plate to control the idle speed.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Check codes, vacuum, throttle linkage, and ISC threads on this forum.
    Dec 2012
    16
    Quote Originally Posted by bigm57ict
    I checked that out and even unplugged it. No change, get a 55 code which is TPS out of adjustment??? It bolts on doesn't look like it is adjustable.
    Quote Originally Posted by cadillac_al
    I get a 55 code (TPS out of adjustment. Unplug that and or idol solenoid and no change. Looking into vacuum leaks now including all of the obvious spots.
    Thanks for the ideas. Always open to more.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: Super high idle - 1992 Fleetwood
    The TPS is adjustable, it's giving the wrong reading to the computer, which in turn is commanding the ISC to move the throttle up until it sees the reading that it wants. Unplugging the ISC simply locks it into its incorrect position and your high idle remains. You have to either retract it fully until it does not touch the throttle lever at all or remove it entirely so you can observe the true TPS reading and adjust it accordingly. You want it to read 0.5v when the ISC is not touching the throttle. Search for the procedure on this board. You cant just slap a new TPS on there - it must be adjusted properly. Don't wait too long, high idle is hard on the transmission.
  10. Remove Advertisements
