82 Eldo Updating Sensors and Wiring
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, 82 Eldo Updating Sensors and Wiring in Cadillac Engine Discussion; Hi all. Due to some hungry mice/rats and age, the wiring connectors for the water and air temp sensors need ...
    edhhjr is offline Cadillac Owners Member
    Automobile(s): 1982 Eldorado
    Dec 2012
    7
    Hi all. Due to some hungry mice/rats and age, the wiring connectors for the water and air temp sensors need to be replaced. Since finding the correct pin connector (pt770) is near impossible, has anyone updated the sensors to the newer style 1985 and up? I know the resistance is lower for the newer style and has a narrower range. Will they work? And can anyone ID this connector on the right side of the tbi, see pic. 3 way, 2 black wires 2 shared blue. Thanks all
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: 82 Eldo Updating Sensors and Wiring
    My car has the newer style sensors with the sort harness provided with them. Its an 84 and works fine. The updated sensors and harness pigtail where recommended by GM as the proper repair. The old style sensor was phased out. The harness would fall apart over time regardless of rodent problems. Simply swap the sensors and solder the short harness to your car's harness then seal with shrink tubing. The other harness was an assembly test connector and has no use.
    Dec 2012
    7
    Thank you very much carnut. Do you know how the new sensors are wired to the old wires? What color goes with what. Ed
    Feb 2003
    california
    69
    6,689
    If I recall they're the same colors.
  7. Remove Advertisements
