1988 Deville 4.5L oil problems in Russia
Results 1 to 15 of 15
HT4100 4.1, 4.5, 4.9 Discussion, 1988 Deville 4.5L oil problems in Russia in Cadillac Engine Discussion; Hello, sorry for my English, I'am from Russia. I have a problem with starting 4.5 engine on my 1988 FWD ...
    Ruedel is offline Cadillac Owners Member
    Automobile(s): '88 Sedan Deville 4.5 TBI
    Nov 2012
    28
    6
    I have a problem with starting 4.5 engine on my 1988 FWD Deville, oil don't fill hydralic lifters and don't came to rocker arms by push-rods, but pressure at sensor is good (when I rotate oil pump mechnically with distributor removed), oil cooler lines are good too. I replaced lifters, but problem is still present. Valves are not open and fuel mixture don't fill cylinders, engine cranked, but not start, fuel stay in intake manifold. Where is my oil?
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: 1988 Deville 4.5L oil problems in Russia
    Engine turns and you get oil pressure, but the valvetrain doesn't move? Broken timing set, cam, or crank?
    Nov 2012
    28
    6
    Yes, valves are not open, but camshaft and timing chain are good, because when I replaced lifters (already contained oil), it start at work good until oil gets out from lifters. Oil from engine don't get to lifters at all
    Feb 2003
    california
    69
    6,678
    A cam bearing has rotated in the block and the oil feed hole is blocked?
    Nov 2012
    28
    6
    Quote Originally Posted by carnut View Post
    Thank you, can I check this bearings without removing camshaft from engine?
    Oct 2004
    Oak Creek, WI
    5,609
    I suppose you could just spin the oil pump drive shaft with a drill and see if oil makes it up to the top.
    However, the cam bearing scenario doesn't explain why the flywheel turns yet the valvetrain doesn't...
    Feb 2003
    california
    69
    6,678
    We have a language problem! He says no oil gets to the lifters so they dont pump up to move the pushrods to open the valves. When the lifters are full of oil, they move the pushrods. That is, at least, what I understand.
    Oct 2004
    Oak Creek, WI
    5,609
    I concur, slight language problem - after re-reading, you are probably right!
    Nov 2012
    28
    6
    You are right, my English is bad, but valvetrain is good I already primed oil pump with drill about 5 minutes, but don't get any oil in lifter gallery. I replaced lifters, pushrods, rocker arms, oil pump, oil filter mount but no result. I think next step will be engine replacement
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I have never heard of this condition in any engine. Do you suppose they might be the wrong lifters? I'm stumped.
    Nov 2012
    28
    6
    Old lifters was replaced because engine works this misfires, smoke etc. I had remove valve covers and see some rockers don't move on running engine and no oil from pushrods. I takes lifters from full operable engine of my another Caddy (Seville '89) and install them into Deville engine, blocks are same. First time engine run great, about 5-10 minutes, until oil don't gets out of lifters. Then turn engine off and it won't start again. I had remove intake and prime oil pump - no oil to lifter valley. In Russia this cars are very rare, and no info in russian internet.
    Feb 2003
    california
    69
    6,678
    I think you have a worn out camshaft. The lifters you removed are probably not flat like they should be. Put a straight edge on the cam surface of the original lifters, if you see any gap between the straight edge and the lifter, the camshaft is damaged. If the camshaft is ruined, it requires engine removal to replace it. In my experience a ruined camshaft also means damaged engine bearings throughout the engine, meaning engine replacement.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Get an oil pressure gauge and test for oil pressure. The pressure at idle is very low on these engines when warm.
  16. #14
    Nov 2012
    28
    6
    I have roller lifters, not flat.
    Quote Originally Posted by dennis93coupe View Post
    Engine not warm up, it don't start at all now. I don't test pressure with gauge, but visually oil flow on both my engines is similar, and on Seville's engine oil gets to lifters then priming, and I already changed oil pump (new is 100% workable)
  17. #15
    Feb 2010
    Orange County, CA
    62
    2,479
    Then as somebody else mentioned, you probably have a spun cam bearing. What happens if you take the lifters out and turn the engine over? Take your spark plugs out to release the compression when turning engine over. If you don't have oil flowing from the lifter bores, then your problem lies deeper than the lifters.
  18. Remove Advertisements
