Timing and error code 26
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, Timing and error code 26 in Cadillac Engine Discussion; Hi guys. I have just replaced most of the sensors and head gaskets etc... So i have made quite a ...
    nizki1981 is offline Cadillac Owners Member
    Automobile(s): 1983 Eldorado ht4100
    Sep 2011
    Mezica, Slovenia
    35
    19
    Hi guys. I have just replaced most of the sensors and head gaskets etc... So i have made quite a service to the car. Now i have two questions. We have tried to set the timming on my car. We have done it quite good but there is one problemm. There is a scale missing on my car and i don't know to wat degrees my timing is set. So is there any other way to tell where is desired 10 or 12 degrees. Now my marker is approx one inch towards passanger side from center of pulley (12 o'clock) car runf pretty fine but when i try to accelerate hard it feals like is getting flodded and it hesitates a bit.
    Secon question is regarding error code. When idling car shows service soon light. When i enter the diagnostics it shows code 26 only. When i gently touch the throttle the light shuts off. So whenever I am touching the throtle the light is off and when i release the throtle the light is on again. I have also replaced Tps and ISC.
    Thanks for the answers
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Timing and error code 26
    Try to get your timing set first and the code might go away. Not sure which 2 locations you jumper on your ALDL, but that should disable the ECM to keep it from advancing when you are setting the base timing. DO you know what the base timing should be?
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Montreal, Canada
    445
    Advance timing, there will be a small green wire with a female plug coming out from the wiring harness near the throttle body. After you set the cold timing you need to ground this green wire to the throttle body to set the Advance timing. SES light will be on, clear the code restart the engine & it should be gone.
    R.
    Sep 2011
    Mezica, Slovenia
    35
    19
    Hi.
    I guess correct cold timing is arround 10 degrees some suggest also 12 degrees. I am running on 95 octane fuel so i think i can use 12. (please correct me if I am wrong).
    For advanced timing I dont know what values shuld I set. So please can you provide me with some data. And Is the procedure for setting advanced timing same as for cold timing (setting the strobe light to cyl. 1, connecting pins A and B on connector,.....) and I shuld just ground the green connector and do the same as for cold timing.
  7. Remove Advertisements
