Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Codes 4.9
    eldoradogary is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Eldorado, 2000 STS
    Jun 2012
    61
    134
    Codes 4.9
    Pulled these codes on my sons '92 Eldorado 4.9, E053, R033 and ECM?
    It's been dying out lately and won't start back up until it is cooled off for awhile. Can anyone help me with what these codes mean? I think the first one has something to do with the distributor.
    Thanks for any help.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Codes 4.9
    Got to this link on how to pull codes. There is a section on OBD I. Post back with your codes AND their definitions. Here's the link...
    http://www.cadillacforums.com/forums...odes-dtcs.html
    Jun 2012
    61
    134
    Re: Codes 4.9
    E053 Distributor Signal Interupt
    R033 Derm Incompatibility
    ECM? Well I can't find that one anywhere.
    Any help appreciated.
  5. #4
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Codes 4.9
    There has been a lot of 4.9 distributors dying lately. They must have been engineered to expire in exactly 20 years lol. It sounds like it could be just the ignition module. I don't recall how much they cost lately but the last one I bought seemed too expensive to me. If it turns out to be something else you may wish that you just bought the whole distributor for $150 or so in the first place. Since it seems to be heat related I would probably gamble on just a new module. good luck.
  6. #5
    69
    82,262
    Re: Codes 4.9
    "ECM?" is not a code. It's asking if you want to move on to the next mode.
  7. #6
    Jun 2012
    61
    134
    Re: Codes 4.9
    Thanks for the info guys, I've got a new Accell cap and rotor and a new Delco ignition module on the way, I'll start from there and see what happens.
  8. #7
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    Re: Codes 4.9
    If the ICM doesn't fix it, look to the pickup coil. That was the culprit on my distributor problem.
  9. #8
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Codes 4.9
    Quote Originally Posted by eldoradogary View Post
    Really, where did you find the Delco ICM?
  10. #9
    Jun 2012
    61
    134
    Re: Codes 4.9
    Thanks for the pickup coil tip, found the ignition module at ebay, Delco Remy brand new in box $15 shipped.
  11. #10
    Jun 2012
    61
    134
    Re: Codes 4.9
    OK, replaced the cap, rotor and ignition module. No more E053 code but still having problems with it wanting to die out or stall when driving. May be a fuel or injector problem, don't know. I guess I'll start by changing the fuel filter. Any ideas?
  12. #11
    Jun 2012
    61
    134
    Re: Codes 4.9
    Changed fuel filter, wasn't the problem.
  13. #12
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Codes 4.9
    I read back through the posts again. You replaced the ICM, right? Did you use plenty of heat sink grease? I know everybody has got to be sick and tired of me asking, but what kind of shape is your harness in inside the distributor?
  14. #13
    Jun 2012
    61
    134
    Re: Codes 4.9
    Yes I used plenty of heat sink grease. Harness still seems ok. Today acted up again and wouldn't start for an hour. Checked codes and now getting current E048. I had cleaned the throttle body and there was a lot of carbon in one of those tubes. So I'm going to pull the EGR valve and clean it up. Should I pull the throttle body to access the EGR easier? BTW the E048 is an EGR code.
  15. #14
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Codes 4.9
    You shouldn't be having the starting problem with that code, sounds like something else.
    Yes it is much easier if you remove the throttle body first. Makes getting to the EGR bolts real easy. I just leave the ISC and TPS on the throttle body when I clean it. NO adjustment needed. Check out your EGR real good, make sure it is clean and no tear in the diaphram. For that matter when you do get it to run at an idle, lift up under the diphram, it should loose a lot of RPM and might even die. Check your harness to the EGR solenoid.
  16. #15
    Feb 2007
    Maine
    55
    3,310
    Re: Codes 4.9
    It sounds to me like the ISC isn't working at all.
  • You may not post replies
