Vacuum connection for heating?
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, Vacuum connection for heating? in Cadillac Engine Discussion; Hi guys! I have 1983 eldorado 4.1 HT. I have some trouble with heating. Car won't blow hot air if ...
    nizki1981 is offline Cadillac Owners Member
    Automobile(s): 1983 Eldorado ht4100
    Sep 2011
    Mezica, Slovenia
    35
    19
    Hi guys!
    I have 1983 eldorado 4.1 HT. I have some trouble with heating. Car won't blow hot air if i have vacuum connected to the vacuum valve (vacuum is constant and valve is closed) if I disconnect vacuum car wont blow cold air any more, just hot. I assume I have connected the vacuum valve wrong while there is no regulation. I can't find out from vacuum diagram where should I connect this valve. So please can you help me where should I connect the heater vacuum valve.
    Thanks
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: Vacuum connection for heating?
    Heater vacuum valve? Do you mean the heater control valve underhood in the heater hose?
    Sep 2011
    Mezica, Slovenia
    35
    19
    Yes I mena that. I've found out that I have connected that valve to THERMAC connection. FALSE. Now I have found two vacuum lines from firewall, one is the MAP sensor. Is other one connection to this heater control valve?
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    The other one might be for the cruise switch down by your brake pedal. You might want to crawl under there and look.
    Feb 2003
    california
    69
    6,689
    If this hose is on the passenger side of the firewall its probably the heater valve hose. That hose should have vacuum with the climate controls set to 60 degrees. Vacuum keeps the heater valve closed. Any setting above 60 will shut off vacuum, opening the valve, allowing heated water into the heater core. You can usually see the lever move on the outside of the valve as vacuum closes it, then watch it move the other direction when you raise the temp setting on the dash.
  8. Remove Advertisements
