pvc valve housing possible vacuum leak?
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, pvc valve housing possible vacuum leak? in Cadillac Engine Discussion; The rubber elbow that houses the pvc valve into the valve cover seems to have a lot of play and ...
    BLMDeville is offline Cadillac Owners Fanatic
    Automobile(s): 95 deville 4.9
    Mar 2012
    29
    114
    The rubber elbow that houses the pvc valve into the valve cover seems to have a lot of play and i was wondering if that could cause a vacuum leak or if it is supposed to be that way
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: pvc valve housing possible vacuum leak?
    When they get hard over time, it may feel loose. As long as it's in the cover and you don't see crankcase blowby coming out around the elbow it should be ok. It would be possible to have a vacuum leak between the PCV and the throttle body, but would be very unlikely. Your most likely location for a vacuum leak would be one of the hoses at the throttle body which I've seen most of the time the elbow for the line going to the EGR solenoid.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    No, it will not cause a vacuum leak. Vacuum is sourced from the restriction that the PCV valve creates. Anything "after" the valve is irrelevant.
