water pump tool?
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, water pump tool? in Cadillac Engine Discussion; Is there a special tool needed to replace my water pump on my 4.9? And any ad vice ob how ...
    BLMDeville is offline Cadillac Owners Fanatic
    Automobile(s): 95 deville 4.9
    Mar 2012
    29
    114
    water pump tool?
    Is there a special tool needed to replace my water pump on my 4.9? And any ad vice ob how to get that bad boy out of there?
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: water pump tool?
    No special tools. 1/2" socket wrench or breaker bar to loosen the belt tension, 13mm combination wrench for the pump pulley bolts, 10mm and 15mm sockets as well as a T45? Torx bit socket for the pump itself.
    Clean the timing cover surface very well, and use NO extra "goop" sealant. If you want to use some of the spray adhesive on the gasket to help hold things in place, that is fine. Also be careful of the finely threaded 10mm components. Don't reef on them, causing damage - spec is only 5 pounds.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    What he said. Permatex Ultra Copper spray is good stuff. Bright orange can, about 8 bucks. Coat both sides of the gasket, let it tack up for ~5min and install.
