Ignition module failing? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
HT4100 4.1, 4.5, 4.9 Discussion, Ignition module failing? in Cadillac Engine Discussion; Put a fuel pressure gauge on the fuel rail and tape it to the windshield where you can see it ...
  1. #16
    donwon is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Deville
    Sep 2004
    SC.
    548
    Re: Ignition module failing?
    while you are driveing. If it starts fluctuateing when it starts skipping, it may be your sign.
  2. #17
    SubieHo is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    21
    On second thought, if no codes are being thrown and fuel pressure tests ok, I would start with the basics and replace the wires if you haven't already done so.
    Wires can often test fine and look ok even after careful inspection, but the connectors inside the boots can wear out over time resulting in poor contact.
  3. #18
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Thank you. Wires are definitely in my list. Not sure how fuel pressure is related to the temperature of the engine in idle.
  5. #19
    mike57 is offline Cadillac Owners Member
    Jun 2008
    9
    The really simple things like a blocked cat are often overlooked.
  6. #20
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Quote Originally Posted by mike57 View Post
    My cat is bad (rattles), but I had had rough idle before it started rattling. Does a bad cat get worse when engine is hot?
  7. #21
    May 2008
    21
    It's usually prolonged misfiring that leads to a rattling cat. Unburned fuel gets dumped into the cat, causing the ceramic honeycomb to overheat and crack.
    Cars can run fine with a rattling cat, but it sure makes your ride sound like crap.
  8. #22
    Jun 2008
    9
    When I had a partially blocked cat I had a discernible loss of power constant stalling and rough idle, not really sure how you test a cat, mabye someone with more knowledge could chime in.
  9. Remove Advertisements
