'82 Fleetwood D'elegance coupe problem :( - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 52
HT4100 4.1, 4.5, 4.9 Discussion, '82 Fleetwood D'elegance coupe problem :( in Cadillac Engine Discussion; It must've happen when I replaced those fuses then when I tested and hard wired the injectors it blew then. ...
  1. #31
    Kadillac G is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac DTS and 1982 Cadillac Fleetwood D'elegance cp
    Nov 2011
    33
    27
    Re: '82 Fleetwood D'elegance coupe problem :(
    It must've happen when I replaced those fuses then when I tested and hard wired the injectors it blew then. But I'm going back in a lil bit to look at exactly what you mention and trace lines. Thanks for all your help bro.
  2. #32
    Feb 2003
    california
    69
    6,663
    Does it run?
  3. #33
    Nov 2011
    33
    27
    Quote Originally Posted by carnut View Post
    Does it run?
    Im actually sitting next to the car as I write this. This is what I've done so far today: first thing was to check and trace the injector wires, they turned up clean and intact. No cuts, pinches or anything. Ok now, the ECM that is for an '83-'84 was still in the car. I put a new 3 amp fuse in the fuse block and turned it to bulb test run. The injector fuse blew. So I went under the hood and switched the injector connectors around. Put a new fuse in and repeated the process. The same fuse blew. So apparently it doesn't matter which injector is connected to that wire, that line will always blow. So I put the "original" ECM back in, replaced the fuse, turned the car to test run, fuse DID NOT BLOW. but when trying to actually turn the car on it didn't try to catch. But with the ECM that doesnt belong in the car, the car will turn on and run until the injector fuse blows out. The original ECM that came with the car is no good is it?
  5. #34
    Nov 2011
    33
    27
    Ok well I put in a new ECM in the car new injectors, and the car STILL won't start. But the car will run pretty damn strong when I pour a lil gas down the throttle body. No longer am I blowing the fuel injector fuse. When I try to start the car and check down in the ports of the throttle body, it's dry. I checked the fuel pressure port and I got fuel going to the throttle body.
  6. #35
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    Did you connect a pressure gauge to the port and get a pressure reading?
    Low pressure could be caused by a pluged fuel filter or even a pluged strainer in the gas tank
  7. #36
    Feb 2003
    california
    69
    6,663
    There is a tool called a "NOID tester" it plugs onto the injector and lights up if power is getting to the injector. This fuel pump requires very low pressure to spray fuel. Can you rent a pressure gauge from an auto parts store?
  8. #37
    Nov 2011
    33
    27
    Quote Originally Posted by 83CADMAN View Post
    I put a brand new fuel pump, strainer and fuel filter.
    Then I'll get the pressure tester tomorrow from autozone. Can I get the noid tester there also? And if not, where can I find it? Is testing the connectors with a multimeter the wrong way?
  9. #38
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Stuff that flickers on and off is hard to test with a multimeter. The pros use an oscilloscope. I use a small 12v interior light bulb, you can see it flash on and off.
  10. #39
    Nov 2011
    33
    27
    Quote Originally Posted by ehall View Post
    Hmmm that's a good idea. If I turn the car to bulb test then the injectors should be pulsing the way they would if the car was running correct?
  11. #40
    Feb 2003
    california
    69
    6,663
    No, the engine must be cranking over for the injectors to pulse. Turning the key to bulb test only powers up the Idle speed motor anticipating a start up.
  12. #41
    Nov 2011
    33
    27
    Ok turns out the reman injectors were locked up. So I paid for new ones from autozone. Before I out the new ECM in, the fuel pump was working (installed new) but now I'm not getting power to the fuel pump connectors underneath the rear bumper. Only place I'm getting power is at the relay (which is also new) and to remind, I replaced the oil pressure sensor and it's connector. Could the MAT sensor or coolant temp sensor tell the ECM to shut power off to the fuel pump?
  13. #42
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Had a similar situation with my 83 Eldo, No power to the FP harness connector at the rear of the car. In my case I kept blowing fuses. The relay checked good so I started back at the tank and chased the wiring, all tested good, but still no power to the pump.
    Turns out the wire to the oil pressure switch had migrated up against and melted to the right ehaust manufold shorting the circut.
    I too replaced a lot of stuff chasing this problem. Good luck.
  14. #43
    Feb 2003
    california
    69
    6,663
    Power is supplied for only a few seconds just after the key is turned to either "run" or the "start" position. While cranking, fuel should spray from both injectors assuming the oil pressure sender sees oil pressure. "Locked Up" injectors? what does that mean? You have power to them, but they do not spray? Wouldn't it be cheaper and quicker to pay someone to diagnose this. diagnosing an engine that doesn't start is much easier than an engine that starts at times.
  15. #44
    Nov 2011
    33
    27
    Yea I supplied power to the old injectors directly from the battery. Burned both of them. Yea I found that the oil pressure switch AND the connector was burned so I replaced both with brand new parts. Would it matter if the fuse for the battery at the fuse box blows EVERY SINGLE TIME I PUT a fuse in the block? I'm very good with cars and never ran into a problem I couldn't fix but the problem is this engine is truly a one of a kind pain in the ass. I don't think regular mechs can diagnose this car
  16. #45
    Feb 2003
    california
    69
    6,663
    The next part you should buy is the factory service manual! This is a very simple 2 injector system. I say again, if its not running a mechanic will be able to diagnose it. The mechanic with the factory manual should have no problem. A blowing fuse is a result of a bare wire touching metal somewhere.
  17. Remove Advertisements
