Results 1 to 5 of 5
Thread: need some help with my 1994 Deville 4.9L v8
    Cadillac210 is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Deville
    Sep 2011
    34
    1
    Question need some help with my 1994 Deville 4.9L v8
    Car sputters when i push on the gas pedal and shuts off. It turns right back on when i turn the key. Only happens sometimes. Has been starting to get worse over the course of a month. Changed the plugs about a month ago, gas is at good level. (When it turns off the gas gauge goes low, and goes up to its level after that.) What could it be?
    (Also the car backfired on me on way to work when i pressed the gas at 53mph.??)
    Last owner used regular unleaded gasoline. I've been using plus instead of supreme. It was working good... owner since January 2011. 85,3## on odometer
    aeronca36606 is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Coupe Deville 4.1 V8 & 4.3 V6 Deisel & 1970 Eldorado
    Sep 2005
    East Tennessee
    773
    Re: need some help with my 1994 Cadillac Deville 4.9L v8
    Check the Fuel Pressure Regulator. Make sure that it is giving the correct pressures. Also remove the vacuum hose from the regulator and check for the presence of fuel. There should be none in the vacuum hose. If there is, Then the Fuel Pressure Regulator Diaphragm has failed.
    Bluezero is offline Cadillac Owners Member
    Automobile(s): 1992 Eldorado
    Aug 2011
    1
    Hey did you ever find out what it was? Seems simple but the same thing happened to me, it turned out to be a clogged fuel filter. Fixed her right up.
  5. #4
    Cadillac12 is offline Cadillac Owners Member
    Automobile(s): 94 4.9 Deville 245k
    Mar 2014
    none
    It could be the a Intermitt MAP sensor.Did you check your codes?
    Good morning. Your CF account is activated. Please update your profile to show proper age, location, car driven and time zone.
  6. #5
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    That was last posted almost 3 years ago!!!! Could be dead by now!
  • You may not post replies
