The best engine to put in my Eldo Cadillac? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Like Tree4Likes
HT4100 4.1, 4.5, 4.9 Discussion, The best engine to put in my Eldo Cadillac? in Cadillac Engine Discussion; well my suggestion to you is to use an oldsmobile 442 engine. i grew up helping my dad build race ...
  1. #16
    rambo45 is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2012
    22
    1
    Re: The best engine to put in my Eldo Cadillac?
    well my suggestion to you is to use an oldsmobile 442 engine. i grew up helping my dad build race cars and the only car he drove was an eldo. In our quest to build a better running race car that would outrun, and last longer we started to see what engines could withstand the heat. Because my dad worked at an autorecking yard we had many cars to chose from, and we found an oldsmobile with a 442 engine. We tested the car out but the car was to heavy, so me and my dad had the idea to pull the oldsmobile's 442 engine, and placed it in his eldo. Because an eldo is alot lighter than most oldsmobiles, we where able to make a better running race car, and a better running car period with an engine that will last a long time.
    KINGUYOM and KINGUYOM like this.
  2. #17
    KINGUYOM is offline Cadillac Owners Member
    Automobile(s): CADILLAC ELDORADO CONVERTIBLE 1985
    Oct 2010
    47
    21
    thank's rambo45 !
    in fact, i need a daily driver eldo, and I think I will consume too much gas with this engine.... in my country gasoline costing two dollars per liter ( that's a shame)
  3. #18
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    In post #6 you were considering a 6 liter engine?? Now there is a thirsty beast. Stick with the orig 4.1, it burns reg gas and will get reasonable gas miliage. Or maybe a Buick 6 cyl out of a Riviara? You could turbo it.
  5. #19
    Oct 2010
    47
    21
    thank you Cadman83
    Oops, you're right, sorry my fault,
    I'm confused and I thought that the 442 Was a racing engine,
    bigger than 6 liter .... misread the message writting by rambo45
  6. #20
    sprocket is offline Cadillac Owners Member
    Automobile(s): '88 Eldorado
    Apr 2010
    MN
    53
    97
    I've got a 4.9 in place of the 4.5 on my '88 Eldo. I have the original intake from the 4.5 so it is still throttle body injection. The fuel injectors are a little undersized for the 4.5 so I compensated by doing a simple procedure that makes the fuel pressure regulator adjustable. I then booted the fuel pressure about as high as I could which was a little over 12 lbs. That's about the only changes I made. The idle is not quite smooth and I have tried every thing under the sun to correct it. It's not a very big deal though. The engine runs great other than that and I get pretty good fuel economy. The avg economy shows 23 mpg right now but I need to confirm that. Changing the fuel pressure could have affected the accuracy of computer calculation for mpg.
    I'm not real familiar with the 4.1, but if the throttle body injection is the same as the 4.5, then you might just need to get injectors from a 4.5 and then increase the fuel pressure like I did. (to change to a 4.9)
  7. #21
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    When I swapped a 4.9 under my 4.1, I used chevy 305 injectors. The 4.9 is 299 CI so 305 is pretty close.
  8. #22
    Apr 2010
    MN
    53
    97
    Quote Originally Posted by ehall View Post
    I did that too at one point. I bought rebuilt ones. I found that the diagnostics showed that the engine ran rich at first until the computer got the feedback from the O2 sensors and then it would go into closed loop and be OK. There still seemed to be a tendency towards the rich side though.
    After going back to the 4.5 injectors and increasing the fuel pressure, the lean issue right after start-up went away, or at least wasn't as dramatic, and once in closed loop, the cross counts are usually very high. My engine seems to like this combination better.
  9. #23
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    MY 1980 coupe deville had the 6.0 liter, 368 engine which is stock for that year,maybe cost a little more for gas, but it's a very reliable and durable engine.
    [QUOTE=creeker;2954015]MY 1980 coupe deville had the 6.0 liter, 368 engine which is stock for that year,maybe cost a little more for gas, but it's a very reliable and durable engine.[/QUOTE
    I should have mentioned, it is not the 8-6-4-, If I was you I would disconnect the 8-6-4. feature and invest a bit of money into the engine your friend has, they are a great
    engine, get it running for as little money as possible and see if it's worth further investment.
  10. #24
    alessio is offline Cadillac Owners Member
    Dec 2014
    1
    ito my days I did over 300 conversion from 4100 to 350 Riviera or tornado 82 and up to 85 tornado or Riviera you need complete engines and crossover pipe and all accessories from the engines than take intake with carburetor and put it in I am the best of he conversion from 4100 to 350 olds
  11. #25
    the APEMAN is offline Cadillac Owners Enthusiast
    Automobile(s): 1980 FBC
    Mar 2010
    54
    557
    This is an old thread but the 368 powered Eldo parts car would have been the way to go. Olds engines are very good too.
  12. #26
    Hatchboss001 is offline Cadillac Owners Member
    Automobile(s): 85 eldo convertible 77 eldo 79 fleetwood bro
    Nov 2015
    43
    6
    Jasper actually rebuilds these motors very well there actually bullet proof after there rebuilt by them with up graded gaskets and a few other things they do before swapping out the motor you should look into the rebuild by this company from what I have heard swapping the motor is not to difficult it's the computers are very hard to get right if anyone has answers to the cpu problems that come up can you reply because I would like to know myself in what works with a swap
  13. Remove Advertisements
