Removing the AIR pump, HT4100
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, Removing the AIR pump, HT4100 in Cadillac Engine Discussion; There has to be a better way. http://www.cadillacforums.com/forums...mp-85-fwb.html (Semi-Emergency - Water Pump, 85 FWB HT4100) In my quest to replace ...
    TheRedSharon's Avatar
    TheRedSharon is offline Cadillac Owners Member
    Automobile(s): 1985 Fleetwood Brougham (Sharon), 1998 Eldorado (Alyson)
    Dec 2010
    Greensboro, North Carolina
    26
    99
    In my quest to replace my water pump, the alternator bracket is the last stumbling block in my path. I've deduced that in order to remove the bracket, I need to loosen up the air pump first. Now from my observations, there is only one bolt on the air pump - on the bottom in the back of the air pump, with the tension adjustment screw. I've gotten under the car several times, and after a while I managed to get a socket on it, but it won't turn. I've tried extending the ratchet handle with a half bat, but there just isn't enough clearance. Right now, I've got the car sitting on jackstands, and I'm going at the bolt from the front, reaching back under the front axle and coming back over top of that to get at the air pump. If anyone here knows a better way to loosen the bolt on an air pump, I would greatly appreciate your help. I really just want this one to be over with
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: Removing the AIR pump, HT4100
    You can carefully unbolt the AC compressor and lay it off to the side if that would help.
    Dec 2010
    26
    99
    Thanks ehall. Thanks to you, I'm almost done.
