"system problem"
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, "system problem" in Cadillac Engine Discussion; I disconnected the ECU on my '89 STS 4.5 liter in anticipation of swapping it out for a junkyard brain ...
    Moondoggie is offline Cadillac Owners Member
    Automobile(s): '70 Eldorado '96 SLS 2001 ESC
    Sep 2005
    21
    "system problem"
    I disconnected the ECU on my '89 STS 4.5 liter in anticipation of swapping it out for a junkyard brain to try and resolve the timing still advancing while the DIC reads "TIMING MODE" with the ALDL A and B jumped issue I then reconnected the brain as it laid loose on the passenger seat floor. The car still runs fine, I drove it to the car wash this afternoon but the DIC is reading "system problem". I can't get that to clear to read any codes. What now? Any experts out there?
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: "system problem"
    Have you tried disconnecting the battery for a few minutes and reconnecting? If nothing happens disconnect again, check your harness connections and you might try removing the prom from ECU cleaning terminals. Put it back together and try that. Do the same with the BCM, remove the PROM and clean terminals, reinstall. Always disconnect battery before removing either of these. Check for poor grounds. And I know you checked all the fuses. Keep in mind that the BCM determines what is displayed, not the ECU. The ECU and BCM communicate, but the BCM actually sends the information.
    Sep 2005
    21
    I disconnected the neg bat terminal and replaced the ECU with the junkyard unit. The car runs fine but DIC reads SYSTEM PROBLEM, same as before. So it's not the ECU.
    Feb 2010
    Orange County, CA
    62
    2,479
    Have you pulled codes to see if you have any? You might be looking for a BCM. I don't know much about STS, so I would suggest going to that forum.
    Sep 2005
    21
    I can't clear "SYSTEM PROBLEM" to read any codes. There were no ECU codes earlier, anyway.
    Feb 2010
    Orange County, CA
    62
    2,479
    Have you tried the STS forum? Might want to give them a try, your problem I would say is more in line with the complete system instead of just an engine problem. I can't say you have a ECU problem (engine control unit) this sounds more like a BCM (body control module). Do you have a FSM? Good idea to get one or try this....
    http://www.alldatadiy.com/
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    According to the FSM its set because of a BCM code being set, for diagnosis it says check sections b334 (loss of ecm data), can you check codes? We can go furthur with it if so ( I have FSM sitting) infront of me
    Sep 2008
    29
    675
    Also it lists B335 and says this in bold pring "BCM Code B335 indicateds a loss of data communication between the CCDIC (Climate control/ Driver Information Center) and the BCM. When this event occurs, the CCDIC will display "SYSTEM PROBLEM" until the condition is corrected
    Sep 2005
    21
    I'm going to the Dana Point St Regis Concours today, will check to see if anything is disconnected early this week. Thanks for the info, guys.
  12. Remove Advertisements
