1985 DeVille Whats That, (Fuel System Canister Valve?)
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, 1985 DeVille Whats That, (Fuel System Canister Valve?) in Cadillac Engine Discussion; hey quys, on my cadillac behind the coolant overflow tank and forward of the right front wheel well is a ...
    jetengine is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    82
    hey quys, on my cadillac behind the coolant overflow tank and forward of the right front wheel well is a canister with hoses going to it and it looks like a electric switch on top of it, i think it has to do with the fuel system, my car was surging alittle i checked all the vacuum lines and found one missing on the canister, i got a new hose, could a missing hose on that item make the car idle surge? thanks
    68
    81,894
    Re: 1985 DeVille Whats That, (Fuel System Canister Valve?)
    That's the EVAP system charcoal canister. If the hose was on the vacuum side (to the manifold), then it is a vacuum leak and can definitely cause a surge.
    Jan 2007
    82
    thank you
