88 seville instrument panel
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, 88 seville instrument panel in Cadillac Engine Discussion; when my rad fan kicks on my instrutment which is digital goes completely out including my driver info center please ...
    bigedd is offline Cadillac Owners Member
    Automobile(s): 1988 Cadillac Seville
    Dec 2010
    43
    1
    when my rad fan kicks on my instrutment which is digital goes completely out including my driver info center please help?
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: 88 seville instrument panel
    That's insane! Those are two separate systems as far as I know. I would try to find something common electrically to the two.... which would be hard since they probably just terminate at the fuse box.
    One thing off the top of my head possibly worth mentioning is that the 55v power supply for the DIC's display lighting is inside the dash cluster. So if the cluster goes out, the DIC usually goes with it. So what's common to both the cluster and the cooling fans?
    I'll have to ponder this one for a while.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    I thought the digital instrumentation were all common to an external power supply? Mounted right above the gas pedal I think...
    Oct 2008
    Palm Bay, FL
    2,024
    Quote Originally Posted by drewsdeville View Post
    This is true (the CPS) but inside the cluster, the voltage is stepped up to 55v and sent to the vacuum florescent displays in the cluster and in the DIC. This is what fried in my last cluster making everything unreadable. The CPS is behind the DIC box under the center of the dash.
  7. Remove Advertisements
