Name the Emission Tube for 1990 4.5
Results 1 to 10 of 10
HT4100 4.1, 4.5, 4.9 Discussion, Name the Emission Tube for 1990 4.5 in Cadillac Engine Discussion; Hi Guys, I'm having a hard time locating this molded emission hose to buy. I also have no idea what ...
    Cristofo's Avatar
    Cristofo is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Sedan DeVille (Sold), 1970 Cadillac Coupe DeVille
    Apr 2009
    Philadelphia
    33
    259
    Hi Guys, I'm having a hard time locating this molded emission hose to buy. I also have no idea what the name of it is...Its located under the intake housing in the rear engine compartment near the firewall (close in proximity to the master cylinder). I think it goes to the rear valve cover? The mechanic gave me the hose and said I should replace it because the flared end is ripped.
    In the following album, the picture is labeled "emission hose"
    http://s1094.photobucket.com/albums/i444/cristofo/
    Any ideas?
    Thanks,
    Chris
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: Name the Emission Tube for 1990 4.5
    Good luck, as they don't make it anymore to my knowledge.
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    33
    259
    Crap, I didnt think so...
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    33
    259
    The tear was minor, so I used crazy glue...good as new!
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    33
    259
    Ok so my crazy glue didnt last and the hose barely holds to the valve cover...Can i replace this with a breather filter that I can stick in the valve cover hole? Since I cant buy a new hose and I dont want to look through junk yards will this be ok? I will cap the hole in the airbox where the hose connected before.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Quote Originally Posted by Cristofo View Post
    Yes, that will work fine.
    Feb 2009
    Jacksonville, FL
    1,023
    The hose is part of the PCV system and is the "draft" portion of said system; a breather filter won't let it do what it was intended to. As for mine, I just wrapped in black electrical tape after I cleaned the crap out and off of it with lacquer thinner. Once done you can hardly tell it was even wrapped.
    Just my .02
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Quote Originally Posted by the recluse View Post
    How do you figure? That hose is only connected to the air box so the PCV can draw clean air from behind the main air filter just like the engine does. This is simpler and cheaper for GM to implement rather that manufacturing a separate part. Connecting a breather filter to that rocker cover accomplishes the same thing.
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by Sevillian273 View Post
    A yes, my thinking was flawed as i was thinking of the system in reverse. To the OP, forget what I said previously; my constituents were correct.
    Sorry for the misinformation
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    33
    259
    Hey Guys,
    Just for fun I decided to see if I could by a new rubber grommet and repair my hose...I cut the end off the hose that connects to the valve cover, then used the new grommet and glued it together. So far so good...If I'm still having issues I'm going to use the breather filter instead. Thanks for you help!
  13. Remove Advertisements
