Engine Swap Process - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 75
HT4100 4.1, 4.5, 4.9 Discussion, Engine Swap Process in Cadillac Engine Discussion; As of tonight he has the new engine in and needs to finish connecting everything. I'm hoping I get her ...
  1. #46
    Cristofo's Avatar
    Cristofo is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Sedan DeVille (Sold), 1970 Cadillac Coupe DeVille
    Apr 2009
    Philadelphia
    34
    259
    Re: Engine Swap Process
    As of tonight he has the new engine in and needs to finish connecting everything. I'm hoping I get her back tomorrow...
  2. #47
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Where are the pictures?
  3. #48
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    Here are just some random pics ive taken through the process.
    http://s1094.photobucket.com/albums/i444/cristofo/
    And here are 2 pictures before the engine went.
    Attachment 73849
    Attachment 73850
    I'll be sure to post all my total disassembly process pics when I get the old engine back to my dads warehouse. I plan on disassembling the whole old engine.
  5. #49
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    Just got a call that he got my car running said it sounded pretty good but had a miss...He started to tap on the injectors and it started to run better with no miss. He's going to swap out the injectors and rail from my old engine to the new used engine.
    Hopefully this corrects the issue and I can be driving me car in not time...
  6. #50
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Tell him to keep all the working injectors from both engines. You may need one or two in the future. They are known for shorting out and are quite expensive new.
  7. #51
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    Good thinking! I'm keeping everything so I have a "parts" set. My original engine ran perfect except for the crack that was leaking out coolant, so most if not all parts should be good.
  8. #52
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    So finally got her back, this can complete this thread. Starting new one...
  9. #53
    Oct 2008
    Palm Bay, FL
    2,024
    A new thread? Uh-oh, that's not a good sign!
  10. #54
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    Quote Originally Posted by Sevillian273 View Post
    Ha, should I not?
  11. #55
    Oct 2008
    Palm Bay, FL
    2,024
    I thought that means it didnt go well!
  12. #56
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    So far so good
  13. #57
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    wow i cant believe the luck i have...driving home from my niece's birthday party and I hear a metal tapping sound. This is after I had zero problems, the car was running good. I pull the car over and look under the hood....the tapping was coming from the pulley area so I shined my flashlight down and noticed the water pump pulley had a very slight wobble (F*$K!). I got in my car to get it somewhere safe when the charge light pops on followed by the hi coolant temp light, so I shut the car off immediately. Pop the hood again...Belt's broke, water pump pulley has 1 bolt left and almost hanging off. Got it towed.
    Only thing I can think is that the water pump seized and broke the belt. Are brand new pumps likely to fail after 50miles of use? WTF! I used the coolant supplement (bars powder) and bought Prestone and new hoses. Could the engine have loosened sludge that I couldnt flush with the hose (I flushed this thing plenty of times until the water came out clear everytime). I trust this mechanic he does good work, so did he do something? All I know is I'm not touching the car until I can get him on the phone and since I only have his work number, I will most likely not get him until Monday.
    This sucks, and it sucks bad.
  14. #58
    Oct 2004
    Oak Creek, WI
    5,607
    Sounds like your mechanic forgot to torque down the pulley bolts. If the shaft/pump are still intact, but the pulley and it's bolts are loose, that's the only explaination.
  15. #59
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    The water pump design is horrible, I went through 4 in 3 years
  16. #60
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    Yeah the mechanic forgot to tork down the water pump pulley bolts. had it happen to me once before it sucks.Replace the bolts and check for leaks and replace the belt. might not be a bad idea to replace the thermostat with a fail safe model. And hey be thankful that the water pump design isint like Mazda nothing like haveing to remove 3 pieces of plastic just to get to it then trying to get to some small bolts that you cant even see.
  17. Remove Advertisements
