4.9 running rough after spark plug change Help!
Results 1 to 13 of 13
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 running rough after spark plug change Help! in Cadillac Engine Discussion; To start with I changed my spark plugs and wires today with Ac Delco Parts, Now my car idles and ...
    Keilyn STS is offline Cadillac Owners Member
    Automobile(s): 1991 Seville STS ,1992 Seville STS
    Oct 2010
    25
    27
    To start with I changed my spark plugs and wires today with Ac Delco Parts, Now my car idles and accelerates rough but when im at a steady rpm it is smooth.
    I also noticed that there is a loud sound like a large vacuum leak near the back driver side of my engine.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: 4.9 running rough after spark plug change Help!
    There are a number of vacuum lines back there, including the vacuum supply to the brake booster which could create quite a large leak. Track down the sound and repair the leak.
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by drewsdeville View Post
    Agreed. Start there. May have removed the main vacuum line in reaching the rear plugs.
    Oct 2010
    25
    27
    ok found and fixed the vacuum leak. My car is still running rough and I dont know what to do.
    Feb 2009
    Jacksonville, FL
    1,023
    Did you pull any codes?
    The other thing you might want to do is check and make sure that all the boots are pressed firmly on the plugs and/or the plugs are tightened to the heads, just a thought...
    If it ran good before the plug change, than it is more than likely something you did/didn't do...
    Oct 2010
    25
    27
    I have no codes, Ill double check over everything tomorrow when I get out of school
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    I had this problem when I did the plugs and wires on the neighbors Caprice. I decided to pull them all and redo the job (reset gap, reroute wires, everything), and it worked great on second try.
    In my case I am pretty sure that I had too much silicon grease on a couple of the plug tips.
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    If you still have problems after checking the above, distrubutor cap, rotor, module would be good places to look/replace.
    Oct 2010
    25
    27
    UPDATE!!!!!!!
    Car will not start now
    I went over the spark plugs and wires multiple times. and nothing
    I noticed when enine was cool it would run good but when it got to operating temp it would start running ban and begin to feel like it had no power.
    the only code im getting is a p052(history)
    Feb 2009
    Jacksonville, FL
    1,023
    Look into your ignition control module and the coil; both can be tested at your local parts house. A failing ICM will give the previous symptoms mentioned...
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    You need to check for spark at the plugs. You will need a friend to help with this. If there is spark then you need to check the fuel pressure. You will have to buy or borrow a gauge. Another way to check the fuel would be to dump a shot of gas down the throttle body and see if it fires. since this is the easiest i would probably try this first.
    Oct 2010
    25
    27
    everything fixed now, needed new cap and rotor, runs like a brand new car
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by Keilyn STS View Post
    Good show....
  16. Remove Advertisements
