4.9 Horrible Idle - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 Horrible Idle in Cadillac Engine Discussion; The battery's been replaced twice in the last year......
  1. #16
    Enigmaticwraith is offline Cadillac Owners Member
    Automobile(s): '93 Deville
    Jul 2010
    California
    59
    Re: 4.9 Horrible Idle
  2. #17
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    Having problems with the ISC on my 90/4.5 myself. I removed the ISC completely and jacked the min idle screw up to get 700rpm and the car runs fine with no codes. Worth a try to narrow down the causes.
  3. #18
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by Enigmaticwraith View Post
    You've got a direct short to ground.
  5. #19
    Jul 2010
    California
    59
    I finally had some time to test some stuff. I couldn't find a vacuum leak anywhere, and I checked the resistance of the injectors. 5 of them read 16.4 ohms, one reads 16.7 and the other two 16.9.
  6. #20
    Feb 2009
    Jacksonville, FL
    1,023
    Well that's good, they're within spec.
    Another possible issue here is a faulty FPS or fuel pressure sensor. Can be had for about $15 and changed out in about an hour. This little number can cause idle issues, hard starts, and stalls. Most of all, it doesn't trip codes. You can test if you have a fuel pressure gauge, but for the cost of one of those you can just replace it....
  7. #21
    Jul 2010
    California
    59
    Quote Originally Posted by the recluse View Post
    Thanks, I'll replace it as soon as I have time to work on it again. Another thing I noticed today: when I opened the throttle blades to double check the EGR tubes, I noticed that I could smell gas coming up out of the open throttle blades. Also, when I tested to check if the PCV valve was working, I noticed that the engine ran much more smoothly for the short time that the valve wasn't in place.
  8. #22
    Jul 2010
    California
    59
    On the way to class today some new problems came up. The SES light came on and I have codes E98 (High RPM P/N to D/R in ISC Range) and E27 (Open Throttle Switch Signal). Also, when the car gets past around 15 mph, it now starts accelerating by itself until it hits about 30-35 mph.
  9. #23
    Feb 2009
    Jacksonville, FL
    1,023
    Run/re-run ISC procedure now that the TPS is back in place.
  10. #24
    Jul 2010
    California
    59
    I already have. It's been adjusted to the correct gap, and it's had the idle learn performed.
  11. #25
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    You are making progress. The new codes tell you that either the TPS is either grossly misadjusted or it's faulty (probably the reason it was disconnected). If correctly adjusting the TPS fails, replace it.
  12. #26
    Jul 2010
    California
    59
    Well, the codes can be crossed off the list of symptoms, along with the other stuff in that post. It seems the ISC connector came loose.
  13. #27
    Feb 2009
    Jacksonville, FL
    1,023
    Fire your mechanic, he forgets to plug s**t back in...
  14. #28
    Jul 2010
    California
    59
    If only firing myself would actually accomplish anything...
    Anyway, I think it's definitely the alternator. I trickle charged the battery overnight and the idle was almost completely smooth this morning when I started it up. However, on the way to class my throttle got stuck open, which was a little scary. I pulled over to look, and the throttle cables were slack and the arm wasn't resting on the minimum air screw or the ISC plunger; it just seemed to have frozen. I fixed it by manually moving back up against the ISC plunger and it didn't do it again for the rest of the drive.
  15. #29
    Jul 2010
    California
    59
    So, I replaced the alternator and it seems that all previous idle problems have been eliminated. Thanks for the help!
    One thing that was never answered and I'm still wondering about though is whether it's normal for some of the fuel injectors to be able to spin back and forth?
  16. #30
    Feb 2009
    Jacksonville, FL
    1,023
    The injector is only pushed in and held with a rubber ring on the bottom and top. The the top has a snap ring as a back up and the bottom is bolted down. Beyond that, the injector can rotate back and forth....
  17. Remove Advertisements
