Intermittent throttle sticking
Results 1 to 10 of 10
HT4100 4.1, 4.5, 4.9 Discussion, Intermittent throttle sticking in Cadillac Engine Discussion; I have been reading and I figure it has to do with the ISC but it is not a constant ...
    skipcarver42 is offline Cadillac Owners Member
    Automobile(s): 1995 Deville, 86K miles
    Dec 2010
    southern Indiana
    32
    I have been reading and I figure it has to do with the ISC but it is not a constant problem. Occasionally when I am slowing for a stop sign or in a parking lot the car will not idle back down. It is a 95 Deville 4.9. Any ideas about a fix?
    MrDobin is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Cadillac Seville Elegante
    Feb 2009
    28
    222
    Re: Intermittent throttle sticking
    Does is ever lurch forward while idling as if the cruise control kicks in?. Had similar with a mild case of stuck down shifting. Codes showed but after I cleared and restarted the car, no issues. Is it throwing any codes?
    Dec 2010
    southern Indiana
    32
    I am new to this forum and honestly did not know I could check for codes until yesterday. I have not yet checked for any codes but will do so today. Thanks for responding.
    Dec 2010
    southern Indiana
    32
    I checked for codes and found a couple related to my problem. I cleared them and haven't had any recurrence of the problem since I cleared the codes. If they reappear I will deal with them properly. Thanks.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    The first thing to check out the free movement of the cable attached to the throttle lever. Besides, clean the back sides of the throttle blades and the bores with carb cleaner. There are also two EGR tubes sticking out under the throttle blades. Clean them up too.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    The ISC is supposed to raise the idle slightly when the brake pedal is depressed. The owners manual describes the idle relearn procedure. The EGR tubes should be checked and cleaned as already mentioned.
    Dec 2010
    southern Indiana
    32
    Thanks for the helpful advice. I will let you guys know how it comes out.
    Dec 2010
    southern Indiana
    32
    Well I am happy to report that after clearing the codes on my Deville I have had no further issues of the throttle sticking or surging, I think some call it "sail on". (knocking on wood and crossing fingers) If I do have further problems I will definitely follow the procedures you people were so kind as to offer. Thank you!
    Feb 2003
    california
    69
    6,680
    Clearing codes never fixes a problem. Once the code comes back and it will, post it here.
    Dec 2010
    southern Indiana
    32
    I cleaned the butter flies and the egr tubes and lubed the cables lightly and generally cleaned things up. She is running fine now and thanks for all the helpful advice. I love my Deville!
  13. Remove Advertisements
