7mpg average! Help if anyone can.
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
HT4100 4.1, 4.5, 4.9 Discussion, 7mpg average! Help if anyone can. in Cadillac Engine Discussion; OK so I am averaging around 7mpg total driving city and highway. I notice whenever I use the gas pedal ...
    Forgoten214's Avatar
    Forgoten214 is offline Cadillac Owners Enthusiast
    Automobile(s): 1992 Sedan DeVille
    Aug 2010
    Northeast PA
    821
    OK so I am averaging around 7mpg total driving city and highway. I notice whenever I use the gas pedal to accelerate I'm getting around 2mpg or 4mpg.
    I don't have a lead foot by any means. I drive pretty much like an old man so I'm told. I just dont know why Im getting such terrible gas mileage.
    I also only use premium gas from Shell or Exxon or Hess so that's not the case.
    I know the EGR valve needs to be replaced due to a E48 error code.
    I also have a E49 code.
    Water pump and Idler pulley also needs to be replaced and I have a hole in my exhaust manifold.
    Can any of these cause such horrible gas mileage? What would be the reason for the vehicle running so rough? It also shakes pretty violently during hard acceleration. It does have abit of hesitation to it.
    I'm just pretty frustrated with the vehicle at the moment but its a work in progress I guess I love Cadillacs and DeVilles and refuse to give up on this car. Its a 90 Deville with the 4.5.
    Any thoughts or help or advise would gladly be appreciated.
    Thanks.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: 7mpg average! Help if anyone can.
    Quote Originally Posted by Forgoten214 View Post
    Its normal to see that on the Inst Mpg display. Take your foot off on the hwy and it will read 70mpg.
    Sounds like you have alot of issues going on at once. I would start with a tune up (plugs, wires, cap, rotor) Then onto the E048 EGR. Also check the resistance of your fuel injectors. All of the above systems can cause your symptoms although I would think something serious would be going on to cause such low mileage. Have you checked the actual fuel mileage via the trip odometer between fill-ups? There would be gray/black smoke coming out of the tailpipe all the time if that much gas was going through the engine.
    Aug 2010
    Northeast PA
    821
    Quote Originally Posted by Sevillian273 View Post
    Yes I have checked it, No I have no smoke. I already did a full tune up, Plugs, Wires, Filters, cap and rotor.
    Im not sure what the problem is with the gas mileage. Yea I did notice that on the highway If I'm going 65 and take my foot off the gas it will read 70mpg. But once I get back on it just to coast the car or cruise I will get about 9mpg on the highway.
    The car shakes violently at those speeds as well.
    Aug 2010
    Northeast PA
    821
    I noticed I used about 6 gallons for about 80 miles as well.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Replace the exhaust manifold and repair the EGR. The hole in the exhaust manifold is causing that bank's O2 sensor to read lean, triggering E49 and giving your bad mileage.
    The EGR problem is likely causing your mileage issues as well.
    Aug 2010
    Northeast PA
    821
    Quote Originally Posted by drewsdeville View Post
    Oh ok thanks, I was quoted over the weekend for 270 to replace the Exhaust Manifold. Is that a fair price?
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    That's 13 miles to the gallon. Is that city or highway?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    yeah sounds like a 'fuel dump mode' situation where the pcm can't tune so it just uses as much fuel as possible to make sure there's enough in the cylinder to ignite
    edit: nevermind... i jumped to conclusions here...
    Aug 2010
    Northeast PA
    821
    Quote Originally Posted by the recluse View Post
    It's highway, yea I was thinking the same thing.
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    Ive only been getting about 12 mpg's with my 4.5 right now . i think the cat might be bad though , but should i take a look at the egr valve as well thought about it but i don't have any codes.
    Oct 2008
    Palm Bay, FL
    2,024
    Quote Originally Posted by quins90lac View Post
    Quin, you said before that you have 19lb/hr injectors in the 4.5. That is your problem. Its been discussed before in other threads. The 4.5 uses 16lb/hr injectors and the computer cant fully compensate for the extra flow. I get 15 mpg on mine.
    Oct 2004
    Oak Creek, WI
    5,609
    ^^^This.
    Now that I've switched to 16lb, I averaged 19-20 in the warm weather, up to 27.5 on the highway. I'm down to 18 now that it's cold out, which is still far better than I ever got with the 19's.
    quins90lac's Avatar
    May 2008
    Peoria IL USA
    35
    616
    i had the 19's in till about a month ago when i first noticed the drop in mpgs . it went up a little bit not much im still at 12 mpg that's why i was thinking it might be the cat gone bad.
  16. #14
    Oct 2008
    Palm Bay, FL
    2,024
    I could definitely see a rich condition from big injectors causing a cat to gum up and fail. The 19's in my 4.5 caused carbon build up in the combustion chambers over time which led to heavy spark knock.
  17. #15
    Oct 2004
    Oak Creek, WI
    5,609
    Yup. Raw fuel in the converter will burn there and superheat the converter, causing meltdown.
  18. Remove Advertisements
