Throttle Questions
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, Throttle Questions in Cadillac Engine Discussion; The other day, I running the car in diagnostic mode to check if the engine was running rich, and noticed ...
    Enigmaticwraith is offline Cadillac Owners Member
    Automobile(s): '93 Deville
    Jul 2010
    California
    59
    Throttle Questions
    The other day, I running the car in diagnostic mode to check if the engine was running rich, and noticed that in the DIC it continuously switched back and forth between E00 and E70 (this was after it showed stored codes). I wasn't sure if these had the same meaning as the normal codes since they were being shown after it put up the history/current codes. Also, I checked the read-out of the throttle angle; it was at 4.6 degrees when the pedal was not being touched and at 77 degrees with the pedal depressed all the way. Is this normal? I would have thought it should be closer to 90 degrees with the pedal fully depressed.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: Throttle Questions
    Not sure what you mean about the E00 to E70 but those throttle angles are normal.
    Jul 2010
    California
    59
    Quote Originally Posted by Sevillian273 View Post
    If I leave the engine running in diagnostic mode, after it shows stored codes it will switch between saying E00 and E70 continuously.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    I believe those are not trouble codes. The DIC finished the codes and asks for further action.
    Jul 2010
    California
    59
    Quote Originally Posted by HUF View Post
    That's what I thought, but I was unsure as I didn't remember it doing that previous times.
  8. Remove Advertisements
