HT4100 (4.5 sleeves) Head Bolt Torque Sequence and Specifications?
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, HT4100 (4.5 sleeves) Head Bolt Torque Sequence and Specifications? in Cadillac Engine Discussion; I am finding differing head bolt torque specs in my manual, web and on here. I know there are multiple ...
    dhuberasu's Avatar
    dhuberasu is offline Cadillac Owners Member
    Automobile(s): Cadillac 1985 fleetwood brougham
    Feb 2008
    bartlett, tn outside memphis
    31
    I am finding differing head bolt torque specs in my manual, web and on here. I know there are multiple posts but could someone help me out?
    I had to pull the head on a long block that I purchased with 4.5 sleeves. The #6 exhaust was stuck tight in the head....first crank bent a pushrod...head is off being fix.
    thank you
    david
    dhuberasu's Avatar
    Feb 2008
    31
    Re: HT4100 (4.5 sleeves) Head Bolt Torque Sequence and Specifications?
    found the specs alldatadiy... thanks
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    If you are not aware, you will need to insert the head bolt threads in the block to get a reliable torque...
