Cold Air Intake?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
HT4100 4.1, 4.5, 4.9 Discussion, Cold Air Intake? in Cadillac Engine Discussion; Hello, I was wondering if anyone here has a Cold Air Intake for their 4.5s or 4.9s? I haven't seen ...
    Forgoten214's Avatar
    Forgoten214 is offline Cadillac Owners Enthusiast
    Automobile(s): 1992 Sedan DeVille
    Aug 2010
    Northeast PA
    821
    Cold Air Intake?
    I haven't seen any only replacement performance air filters. Was curious to see if anyone had any custom intakes or if there are any bolt on options.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: Cold Air Intake?
    The stock intake system is already pulling in "cold air" from just behind the headlight. You can't get much better than what's already there.
    If you want to gauge what kind of gains you'll get from a "low restriction" air filter, take your air filter out and take it for a drive.
    Performance-wise, you'll gain nothing. The most you could gain is a louder intake sound, creating the illusion of more performance.
    Aug 2010
    Northeast PA
    821
    Oh ok, Is there any difference with using K&N or Spectre air filters? Right now I'm just using FRAM from Walmart. lol
    Oct 2004
    Oak Creek, WI
    5,609
    Aug 2010
    Northeast PA
    821
    AC Delco seems to be the best there, Do they make any that will fit the 4.5 or 4.9 intakes?
    Oct 2004
    Oak Creek, WI
    5,609
    They sure do, that's what your car originally came with. Any local parts store should have them.
    Aug 2010
    Northeast PA
    821
    Any chance Amazon has it? I have a few bucks left over I need to spend in my Cart I will just order it now. If not I'll get the Spectre from them I guess.
    Rodya234's Avatar
    Rodya234 is offline Cadillac Owners Connoisseur
    Automobile(s): 1998 Seville STS / 2013 Chevrolet Impala
    May 2008
    Chicago, IL
    24
    1,889
    Even though the stock Cadillac intake does take cold air in from behind the light, there is a significant amount of improvement that can be done to the stock air box design. For one, the stock intake necks down to about the size of a golf ball at the intake opening, and the accordion-flex piece built into the neck is extremely detrimental to airflow. Secondly, the incoming air charge has to make two 90 degree turns on its way to the throttle body. (Where the 4.9's real flow restrictions are would be the cast iron cylinder heads, intake and exhaust manifolds, but that's off topic.)
    A member of this forum, Ghost C, used to make a very nice intake for these cars, but he doesn't really come around anymore. I've been trying to get one for months.
    Aug 2010
    Northeast PA
    821
    Quote Originally Posted by Rodya234 View Post
    Nice, Do you happen to have any pictures of the modifications?
    Rodya234's Avatar
    May 2008
    Chicago, IL
    24
    1,889
    There are no real modifications to the stock airbox that I know of, but I'm sure some could be done. This is a picture of Ghost C's intake, which is probably the best one available for these cars.
    As you can see, it is much straighter and smoother than the stock airbox, which provides a decent amount of flow increase. Also, the evap canister has to be relocated a bit further down from its original position to accommodate the filter, but from what I understand all that means is you have to extend some wires.
    I really wish you could still get these
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,235
    the usual slow, double, saturday night post screwup..............
    Feb 2006
    56,235
    Remember: The First Law of Modification is : Do No Harm.
    Before you fall for the hype and sales pitches, do a dyno run before you change anything.
    Then do your modification work, one step at a time, with dyno runs at each step.At any step, if you lose power (a real occurrence, and common) then go back and try again.
    You'll find that the so-called "CAI power gains" are mere advertising hype designed to get into your wallet. Unless you're driving a highly tuned production line engine which must not only run like hell but also meet customer satisfaction goals you'll find that cutesy mods for our cars are eye candy - nothing else. If it only makes more noise (absent real dyno/drag times), it isn't faster - probably slower.
    "But, Sub - I can't afford all that testing". Right, and the aftermarket hypers KNOW THAT.
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    A 4inch dryer pipe works real good as well then all you need is a filter. right now im designing a dual 4 in intake set up . don't know if it will help any thing but it will sure look cool
  16. #14
    TK8411 is offline Cadillac Owners Member
    Automobile(s): 94 Deville
    Mar 2011
    WPB, FL
    32
    21
    I improved my 4.9 stock air intake setup with some 3 inch pvc pipe, a 22 degree elbow, a velocity stack, duct wrap insulation and a K&N filter. Also relocated IAT sensor. I felt an improvement. MPG seem to be going up. The stock setup has a 1 7/8 inch opening. Materials cost me roughly 40 bucks but I got plenty of leftover pvc ancd insulation so I'm going to make a cold air intake for my sister's Buick.
  17. #15
    Aug 2010
    Northeast PA
    821
    Quote Originally Posted by TK8411 View Post
    Do you happen to have a picture of your setup or can you take some?
  18. Remove Advertisements
