| HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines. | Cadillac Forums: I replaced my tps and isc but it stall every now an then
09-17-04, 10:20 PM
| | Cadillac Owners Member | | | | | I replaced my tps and isc but it stall every now an then I replace both of them but it still stall every now and then it use to stall out when i used to back the car out but it stall out out every now and then when i turn a corner driving |
09-18-04, 12:05 AM
| | Cadillac Owners Fanatic | | | | | Re: I replaced my tps and isc but it stall every now an then Quote: |
Originally Posted by Caddy_2004 I replace both of them but it still stall every now and then it use to stall out when i used to back the car out but it stall out out every now and then when i turn a corner driving | What car and engine? |
09-18-04, 02:03 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante | | Join Date: Feb 2003 Location: california Age: 62 | | | Re: I replaced my tps and isc but it stall every now an then what year, what car? |
09-18-04, 08:37 PM
| | Cadillac Owners Member | | | | | Re: I replaced my tps and isc but it stall every now an then Caddillac eldraodo 1986 4.1 engine |
09-18-04, 10:38 PM
| | Cadillac Owners Fanatic | | | | | Re: I replaced my tps and isc but it stall every now an then How did you adjust the TPS and the ISC motor? Have you used the search feature on the forum to search using "idle speed control motor" or "ISC motor"? If not, do that and read about how to retract the ISC motor plunger manually and adjust it. |
09-19-04, 12:16 AM
| | Cadillac Owners Member | | | | | Re: I replaced my tps and isc but it stall every now an then I had got my mechanic to do it for me but I had got the tps first then he adjusted it then a week later I got the isc and it was adjusted it seem like the the rod that move when u crank it up slack to the side and i have to push it up
These the code I get
E013 been replaced withe dealership oxy sensor cause bosh didnt work
E047
E052
E053
E055
E059
The code for the ISC and TPS went out as soon as I install the sensor
thank for helping me |
09-19-04, 03:14 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante | | Join Date: Feb 2003 Location: california Age: 62 | | | Re: I replaced my tps and isc but it stall every now an then The idle speed motor must be retracted per the service manual then the gap between it and the throttle arm verified. If just bolted on and curb idle set, it could be incorrect. To properly diagnose and work on these fuel systems , you MUST have access to the factory service manual, not Chiltons, not HAYNES, the factory service manual. I have found these systems relatively easy to work on if the manual is used. If the TPS reference voltage is incorrect a fuel delay could occur, causing a bog or stall off idle. The manual is very specific about adjusting both TPS and idle speed motor at the same time. One references operation from the other. |
09-19-04, 11:34 PM
| | Cadillac Owners Fanatic | | | | | Re: I replaced my tps and isc but it stall every now an then E013 Been replaced with dealership oxy sensor cause bosch didn't work
E047 BCM-ECM data communication problem
E052 ECM keep alive memory reset (could be a simple battery disconnect)
E053 Distributor signal interrupt
E055 TPS misadjusted
E059 VCC temperature sensor circuit problem
To set your ISC motor and TPS on your engine you need to warm it up, idle it and turn the AC off. Hold the throttle lever open to elevate the engine RPM to 2500 or so and, while holding the throttle open, depress the plunger of the ISC motor. When depressed it should retract as long as you hold pressure on the plunger and keep the RPM up. Once it stops, disconnect the wire connector to the ISC motor electrical connector without letting the ISC motor plunger move. Once the ISC motor plunger is retracted, release the throttle to idle. The engine should idle at 450-475 RPM and there should be clearance between the plunger and the throttle lever. If there's no plunger, and you're sure that the plunger is fully retracted, then screw the plunger in until there's clearance. Make sure the cruise link doesn't hold the throttle open - disconnect it if necessary. If the throttle is closed and the idle is above the 450-475 point then adjust the throttle stop screw to get the closed bore idle speed correct. Once adjusted, the TPS will need to be back probed and the set up voltage checked with a DVM. You're looking for .5 volts if it's adjusted correctly. Move the TPS until it shows .5 volts at the closed bore throttle setting. Once the TPS is set, adjust the ISC plunger so that there's about .020 clearance between the plunger and the throttle lever. Reconnect the cruise control link so that there's just a little slack in the cruise link while the throttle is still at the closed bore position. Now hook up the wire connector to the ISC motor. Disconnect the negative battery terminal for 60 seconds and then reconnect. You should be good to go. |
09-19-04, 11:51 PM
|  | Cadillac Owners Master Cadillac(s): Jeep: '05 TJ Sport 6spd BMW: '90 325iC & '92 318iC both 5spd | | Join Date: Mar 2003 Location: Middle Georgia Age: 22 | | | Re: I replaced my tps and isc but it stall every now an then Question here...
my 4.9 ('93 DeVille) has a slight hesitation at idel... if I hit the gas from a stop, or even in park, for a split second she'll hesitate, then rev up... my father says the TPS is bad... yet there are no codes of any sort.... would the TPS cause this? is it something i should even be bothered about? |
09-20-04, 11:30 PM
...hard to say. It could be but not likely as the TPS will set a code as it starts to fail almost always. I would check the EGR tubes for cleanliness. Have they ever been cleaned out? Also, check the fuel pressure with a gauge. Have the gauge on the rail when you step into the hesitation you describe so you can see if the fuel pressure is the problem. It should stay very steady when you tip into the throttle. If it drops then the pump may be failing and low on capacity. Did you check the fuel pressure regulator? |
09-21-04, 12:20 AM
|  | Cadillac Owners Master Cadillac(s): Jeep: '05 TJ Sport 6spd BMW: '90 325iC & '92 318iC both 5spd | | Join Date: Mar 2003 Location: Middle Georgia Age: 22 | | | Re: I replaced my tps and isc but it stall every now an then At first I was thinking the EGR tube was cleaned.. but that was my Olds... so for as long as I have had the car, the EGR hasn't been touched.... I havn't check fuel pressure either... I should get a pressure meter from the store...
...it only does it if it has been ideling.. if I hit the gas, let it idel for a second then hit it again, she'll rev right up... but if it has been idling for... say 20seconds or more... when I hit the gas there is a "blip" and then then the RPM comes up... |
09-21-04, 12:01 PM
| | Cadillac Owners Member | | | | | Re: I replaced my tps and isc but it stall every now an then I know a little about a Cars but what is EGR TUbe |
09-21-04, 11:31 PM
|  | Cadillac Owners Master Cadillac(s): Jeep: '05 TJ Sport 6spd BMW: '90 325iC & '92 318iC both 5spd | | Join Date: Mar 2003 Location: Middle Georgia Age: 22 | | | Re: I replaced my tps and isc but it stall every now an then what is the best way to clean the EGR tubes as well? | | Cadillac Discussion Tools | | |
Censor is ON | | | |
