e23 and e27 - Page 5
Page 5 of 5 FirstFirst 12345
Results 61 to 66 of 66
HT4100 4.1, 4.5, 4.9 Discussion, e23 and e27 in Cadillac Engine Discussion; Originally Posted by Reverend Hearse Hmm..... 65 bucks an hour vs using my spare trans w/ shift kit... Decisions.... You ...
  1. #61
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Quote Originally Posted by Reverend Hearse View Post
    You didn't tell me you had one of those!
  2. #62
    Reverend Hearse's Avatar
    Reverend Hearse is offline Cadillac Owners Member
    Automobile(s): 1984 Collins hearse, 1979 Coupe , 1984 Seville,1990 fleet'
    Oct 2010
    32
    86
    Re: e23 and e27
    didnt want to pull it if i dont have to, still lugging down when hot, still slamming back through the gears when slowing down....
  3. #63
    Oct 2010
    32
    86
    Re: e23 and e27
    So , what are these 2 parts, can they be easily removed? I believe one is the a.i.r. Pump? And is it possible to do away with the a/c and still have p/s?
    EDIT* CANT GET THE PICS TO LOAD, ONE IS PULLY IS RAN BY THE P/S PUMP VIA A SHORT BELT, AND THE OTHER ITEM IS DIRECTLY UNDER THE ALTERNATOR, RAN BY A BELT BACK TO THE CRANK I BELIEVE, WHAT ARE THESE 2 ITEMS AND CAN THE BE REMOVED?
  5. #64
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Pics would be really helpful...
  6. #65
    Oct 2010
    32
    86
    Re: e23 and e27
    I figured the air pump belt needs replaced, the adjuster bolt seems to be designed by the russians, as i cant seem to get to it no matter how i try, i have pulled the alternator to try and gain more room, but i really dont see and good way other than to remove the passenger side tire, certainly there is a simple way, what am i overlooking?
  7. #66
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    ...seems to be designed by the Russians, as i cant seem to get to it no matter how i try...
    In Soviet Russia; bolt gets you
    Sorry
    You have to remove the tire. Behind it is a "flap" that you unbolt and move out of the way for easier access to all things south of the water pump....
  8. Remove Advertisements
